Smoker Designs: Offset, Reverse Flow and What to Build
Before you buy steel, decide how you want the pit to cook.
The design follows from that.
The way a pit cooks gets welded in when you build it. The baffle, where the stack goes, where the firebox sits… none of that changes later without major fabrication and rework.
So here are the smoker designs I'd actually look at for a homemade offset, how the heat moves through each one, and what you give up with each.
Already know which design you want? Every plan set I've drawn is at smokerplans.net, offsets and reverse flows in a lot of sizes. Browse smoker plans
Key facts from Frank Cox, The BBQ Pit Engineer
- The three main designs are a traditional offset, a reverse flow and a scoop (vertical) baffle offset.
- For a first build, I recommend a straight offset.
- A reverse flow is even by design. Its stack moves to the firebox end, and it's heavier.
- Most offsets run in zones and can be hotter toward the firebox end. A scoop on a buoyant, balanced design typically cooks even.
Last updated November 27, 2026
Start with one question
Do you want even heat from one end of the chamber to the other? Or are you fine working around a hot end and a cool end?
If you mostly cook one or two big cuts at a time and want the most smoke into them, I lean offset. If you fill the whole chamber with a lot of same-size pieces that all need to finish together, reverse flow's even temps make that easier.
Keep your answer in mind as you read the rest.
Traditional offset
Firebox on one end, stack on the other.
The heat comes in from the firebox side and fills the chamber from the top down. It stacks up until it gets to the stack outlet, and that's when the draft gets going.
On most offsets the temperature runs in zones and can be hotter toward the firebox end. That happens when the pit isn't designed to be buoyant and balanced. My numbers and design methods are built for a buoyant, balanced pit.
- Good at: it's the simpler build, and you get a strong wood smoke flavor.
- Tradeoff: unless it's designed to be buoyant and balanced, it can run hotter toward the firebox end.
- Suits: a first build, and anybody who wants the classic stick burner and doesn't need every rack the same.
Reverse flow
The stack moves to the firebox end, and a solid baffle plate gets welded in under the grate.
The heat runs the length of the chamber under that plate, turns around at the far end and comes back over the top before it goes out the stack. That out-and-back path is what evens the temps out end to end.
- Good at: even temps end to end, and it's a much moister environment in there.
- Tradeoff: more steel and more welding. The baffle is in there for good. And it can run too clean for my taste.
- Suits: somebody filling the whole chamber with same-size pieces who'd rather have even racks than the most smoke flavor.
One thing about the stack on a reverse flow. I would completely not recommend moving your smokestack down. The air cools off too much and condenses, and I've actually seen it completely plug a smokestack before. Keep it up at the top and get that air out of there as fast as you can.
Vertical baffle with a scoop
Vertical-baffle offsets with a scoop at the throat… that's my favorite right now.
It's still an offset. Firebox on one end, stack on the other. The difference is at the throat.
The scoop is a vertical deflector right at the throat. The air coming out of the firebox already wants to rise, and the scoop works with that and sends it up, so it doesn't speed the air up or build back pressure.
A downward deflector plate pushes the air mass farther out into the cook chamber. But the air still wants to go up, like nature intended. So all it does is push the original problem farther out into the chamber.
The scoop turns the air up the second it comes out of the firebox. The air rises, rolls across the top, and that turn makes it a little more lazy as it comes back across the bottom rack. That's the undertow you want.
- Good at: it protects the meat on the firebox end, makes that hot end usable, and keeps the flavor of an offset.
- Tradeoff: with a vertical baffle the top rack runs at least 100 degrees hotter than everything else. If you need two even levels for production cooking, I'd point you to a reverse flow instead.
- Suits: a single-level offset where flavor matters.
Tuning plates and hybrids
Tuning plates are basically the reverse flow baffle plate cut up into sections. Take the full length of the baffle plate, take off about 3" for the gap, and cut the rest into staggered pieces from 12" down to 4". Set the gaps between them closer together at the firebox end so less air comes up through, and farther apart as you move away from the firebox so more comes through. Tuned like a guitar.
That design is becoming outdated as popularity grows for the traditional offset designs.
A hybrid is a reverse flow and offset combo. Two stacks, and cut-up tuning plates in place of one solid baffle, so you can run it more than one way. It's flexible. It's also more complicated to build and easier to get wrong. I'd save it for a second build.
Reverse flow vs offset: quick answers
Which is better for a first build, a reverse flow or an offset?
A straight offset. It's the simpler build. There's no full-length plate to fit and weld solid, so it's less steel, less welding and less weight on the trailer.
Which one cooks more evenly?
A reverse flow is even by design. The plate makes the heat run the full length and come back, and the plate itself soaks up heat under the grate.
Most offsets can run hotter toward the firebox end unless they're designed to be buoyant and balanced. Put a scoop at the throat on a pit that's designed to my balanced standards and it typically cooks even from end to end.
What changes in the build for a reverse flow?
- A solid baffle plate gets welded in the full length of the chamber.
- The stack moves to the firebox end, top dead center.
- The firebox mounts lower. Its top sits at least 2" below the cooking grate. On an offset it can land anywhere from the grate up to flush with the inside top of the chamber.
The cutting order stays the same on both. Firebox hole first, then the stack hole, then the doors, so the shell doesn't twist on you as the stresses let go.
Why does the stack go on the firebox end of a reverse flow?
Because that's where the air ends up. The plate sends the heat to the far end and turns it around, so it finishes its trip back at the firebox end. That's where it has to leave.
Is a reverse flow heavier than an offset?
Yes. It's the same tank plus a full-length plate and the welding to put it in, so it's heavier and takes more shop time. It also hangs lowest, so watch your trailer ground clearance. Keep at least 8".
More on sizing and welding in the plate: Smoker Baffle Plates. More on mounting the firebox for each one: Offset Smoker Firebox Design.
Baffle plate design
Reverse flow baffle plate
Use 1/4" plate. If you have an eighth inch thick baffle plate, you don't have enough thermal mass to absorb the heat out of the airstream.
That plate is doing two jobs. It's a divider, and it's a heat sink. It slows the air down so the steel can pull heat out of it, kind of like the turbulator in a furnace.
It welds in under the grate and runs the length of the chamber. Weld it solid to the chamber walls. That keeps the grease on top of the plate so it runs to the drain, instead of getting under a plate that's heavy and hard to pull out to clean.
Keep the grate at least 2" above the plate. 4" is better. Any closer and the heat coming off the plate scorches the bottom of the meat.
Size the return gap at the far end by open area, not by a distance. I start at half the throat area. The window is 0.50 to 1.25 times the throat area.
Build in a grease drain tube, and plan on getting under that plate to clean it. That's part of owning a reverse flow.
Vertical baffle and scoop
It doesn't have to stand way up over the grate. Get it about 1-1/2" up past the throat opening and the heat still goes up.
It doesn't have to be welded in either. My first one was a loose plate with little feet that stuck out about 3" each way to keep it from tipping over.
What doesn't change how it cooks
Some things people worry about don't matter as much as they think.
The shape of the chamber. A propane tank, a section of pipe, plate rolled into a cylinder, an octagon, a rectangle. They all cook the same. A smoker runs on draft, and draft comes from the height of the stack and how hot the air is, not the shape of the box. So build the shape you can actually make.
To be fair about it, a flat-sided box has a little more wall for the same volume. A square has about 13% more than round, an octagon about 3%, a 2-to-1 rectangle about 20%. That means a touch more fuel in cold weather or wind. It doesn't change how it cooks.
Exactly where the firebox lands on an offset. Anywhere in its range cooks fine… the air doesn't care where you land. More on that range below.
What gets welded in
These are the decisions you're making for good when you pick a design.
The baffle. Solid reverse flow plate, tuning plates, or a scoop and vertical baffle. That sets the whole path the air takes. If you're sizing the gap on a reverse flow plate, size it by open area: 0.50 to 1.25 times your throat area. Start at 0.50.
The stack location. Far end for an offset. Firebox end, at the top, for a reverse flow.
Firebox height. It follows the cooking grate. We like the grate at the 3:00 door cut.
- On an offset, the top of the firebox lands at or above the grate. It can go as high as flush with the inside top of the chamber. What decides it is room for the throat, ground clearance on a trailer (8" or more), and loading height and looks.
- On a reverse flow, the top of the firebox sits at least 2" below the grate. That leaves room for the baffle. It's why reverse flow fireboxes hang low, and why they're the ones that fight you on trailer clearance.
You'll hear "halfway" and "two-thirds" thrown around. Both can be right. Both only work when you know where the grate sits.
How the baffle choices compare: What Kind Of Baffle Should I Use For An Offset Smoker? and The Difference Between Reverse Flow and Offset Smokers
Other pit types
This page sticks to offsets. A few other designs I teach:
Drum smoker (UDS). The cheapest way into a homemade smoker. A plate blocks off the space around the heat shield so all the intake air has to go up through the charcoal basket. No way around it. Drum steel is thin, about 1/16", so it comes up to temp fast and needs feeding more often.
Gravity feed. A charcoal hopper feeds the burn chamber. A sealed top door keeps the charcoal stacked above from lighting early, and the ash box sits under the charcoal grate. More here: Gravity Feed 101
Vertical cabinets are their own family too, including vertical reverse flow. That one deserves its own page.
Once you've picked the design, the next question is how to build it. Here's the order I build a propane tank offset in: How to Build a Smoker: The Build Order, Start to Finish
If you want to go deeper on design, that's what SmokerBuilderU is for. Bring your design questions to the live Q&A I do every Wednesday night at 7pm Central.
If you already know what you want, every plan set I've drawn is at smokerplans.net, offsets and reverse flows in a lot of sizes. Fully dimensioned, ready to download.
Browse smoker plans
PS. Pick the design before you pick the tank. The design decides the rest.
What is the best smoker design?
It depends on how you want it to cook. If you want even temps end to end for a full chamber of same-size pieces, reverse flow. If you want the most smoke flavor and the simpler build, an offset. My favorite right now is an offset with a vertical baffle and a scoop at the throat.
What is the difference between a reverse flow and an offset smoker?
On an offset, the firebox is on one end and the stack is on the other, so most of them can run hotter near the firebox unless they're designed to be buoyant and balanced. On a reverse flow, a solid baffle under the grate sends the heat to the far end and back, and the stack sits on the firebox end. That evens out the temps.
How thick should a reverse flow baffle plate be?
1/4". An 1/8" plate doesn't have enough thermal mass to pull the heat out of the airstream. Weld it solid to the chamber walls, keep the grate at least 2" above it, and size the return gap at the far end to about half the throat area to start.
How do you lay out tuning plates in an offset smoker?
Take the full length of the baffle plate, take off about 3" for the gap, and cut the rest into staggered pieces from 12" down to 4". Set the gaps tighter at the firebox end and wider toward the far end.
How tall does a vertical baffle need to be?
Not very. About 1-1/2" up past the throat opening is enough to turn the heat up.
Does the shape of the cook chamber matter?
No. A tank, pipe, rolled cylinder, octagon or rectangle all cook the same, because a smoker runs on draft. A flat-sided box uses a little more fuel in cold or wind, but it cooks the same.
Can I change my smoker's design later?
Not easily. The baffle, the stack location and the firebox height get welded in. Changing them later means major fabrication and rework, so decide before you buy steel.
Where does the firebox go on an offset vs a reverse flow?
Both follow the cooking grate. On an offset, the top of the firebox lands at or above the grate. On a reverse flow, it sits at least 2" below the grate to make room for the baffle.
Which is better for a first smoker build, reverse flow or offset?
A straight offset. It's the simpler build, with no full-length plate to fit and weld solid, so it's less steel, less welding and less weight.
About the author. Frank Cox, The BBQ Pit Engineer, founded SmokerBuilder in 2010 after a career in refrigeration, HVAC and food equipment that now spans 32 years. By his best estimate, he has built more than 1,000 pits in total and drawn more than 240 plan sets. His plans are at smokerplans.net, and he teaches the build step by step inside SmokerBuilderU.
