Is Feldon's Calculator Flawed? I Checked It Against My Numbers
One of you asked me this under a 500 gallon build: "Smoke stack looks super tall. Did you use one of the firebox, cook chamber, and smoke stack calculators for optimal airflow and stuff?"
The calculator most guys mean is Feldon's. And the next thing they ask is whether it's flawed.
It isn't. I ran it against my own numbers. The firebox it gives you lands inside my range, and the throat is the exact same formula I use.
If you want a calculator, use Feldon's. Just make sure it's the real one.
And if you'd rather not use one at all, the math underneath is simple enough to do with a tape and a calculator… I'll show you both.
Rather start from a drawing with the numbers already worked out? My plan sets are laid out by tank size. Find the plan for your tank
Is Feldon's calculator flawed?
No. Its firebox and throat numbers land right where mine do.
There are things it leaves out, like the collector box and scoop baffles. That makes it a simpler tool. It doesn't make the numbers it gives you wrong.
It's an older worksheet, copyright 2011 to 2012, and it's honest about the parts it doesn't pin down.
Where is the real Feldon's calculator?
Here: Feldon's BBQ Pit/Smoker Build Calculator on feldoncentral.com.
The real one carries Morgan Feldon's copyright and credits Alien BBQ and Tom C from TheSmokeRing.com for the method. It's version 3.7.
There are copies of it floating around the internet. That's the next thing to talk about.
Why should I watch out for fake calculator sites?
Because bad actors copy free tools and use them to get something out of you. Here's what to look for:
- It wants your email first. Or it's buried in ads, or asks you to pay to see your results. The pit math has always been free.
- The author's name is gone. A copy that strips off the copyright and credits isn't the source.
- A ratio got changed. This is the one that hurts. You can't see it from the outside. The numbers just come out wrong… and you cut steel to them.
No calculator ever needs your email or your card to show you a firebox size. If one asks, close the tab.
The best protection is knowing the two checks further down this page. You can test any calculator by hand in a couple minutes.
What does Feldon's calculator do?
It's a worksheet. You give it the shapes and sizes of your steel:
- Cook chamber: a cylinder or tank (diameter and length), or a rectangle (height, width and length)
- Firebox: square (height, width and length) or round (diameter and length)
- Chimney: the pipe diameter you plan to use
- Air intake: square or round
It gives you back the cook chamber volume, a recommended firebox size, how far your firebox is from that recommendation, chimney volume and length, air inlet area and how many intakes, and the opening between the firebox and cook chamber, as a round hole or a half-moon.
It'll also make a link so you can save or share a build.
How does Feldon's firebox size compare?
Feldon sizes the firebox at one-third the volume of the cook chamber. He also says a slightly oversized firebox beats an undersized one.
I start at 0.30 times the cook chamber, with a best practice range around it.
One-third is 0.333. That's a hair bigger than my starting point, and it still lands inside my range, on the high side. That holds for an offset and for a reverse flow.
| Cook chamber | Feldon's firebox | My starting point | My range |
| 250 gallon | 83.3 gal | 75 gal | 62 to 88 gal |
| 500 gallon | 166.7 gal | 150 gal | 125 to 176 gal |
Same target, rounded a little differently.
Does Feldon's calculator size the throat the same way?
Yes. Exactly the same.
The throat is the opening between the firebox and the cook chamber. Feldon sizes it as firebox volume in cubic inches times 0.008, and the answer is square inches of opening. That's my formula too. Same reference, same number.
| Cook chamber | Firebox used | Throat area |
| 250 gallon | Feldon's third, 19,250 cu in | 154 sq in |
| 250 gallon | My 0.30, 17,325 cu in | 139 sq in |
| 500 gallon | Feldon's third, 38,500 cu in | 308 sq in |
| 500 gallon | My 0.30, 34,650 cu in | 277 sq in |
The small difference in each pair comes from the firebox, not the formula. A bigger firebox gets a bigger throat. Put the same firebox in both and you get the same throat out.
One more thing on the throat. Think in area. On a 500 gallon, 308 square inches works out to a round hole almost 20" across. You don't cut that. You cut a half-moon or a slot with the same area. That's why Feldon's tool gives you a half-moon option.
How does Feldon's calculator handle the smoke stack?
Feldon targets a chimney volume of 5% of the firebox volume. You pick the pipe diameter, and he gives a typical exhaust length of 30 to 40 inches.
I size the stack diameter by the size of the tank, and make the length at least half the length of the cook chamber, never under 33".
His 30 to 40 inches straddles my 33" minimum, so the length lines up on a lot of pits. We just get there a different way. He doesn't give a hard length formula, and he says so.
It's looser than how I do it, and he labels it that way.
Does Feldon's calculator work for a reverse flow?
For the main opening at the far end, yes. Feldon says that opening, opposite the firebox, should be at least as big as the throat, and it can run bigger.
I set that gap at 0.50 to 1.25 times the throat area, starting at 0.50. That window is for a reverse flow baffle plate only.
So the two overlap from 1.0 to 1.25 times the throat.
Feldon's tool doesn't have a scoop or vertical baffle option. And the reverse flow window doesn't apply to a scoop, so don't borrow it there.
What doesn't Feldon's calculator cover?
- Insulated firebox. There's no input for it. That's fine. Insulating the firebox doesn't change its size anyway.
- Scoop and vertical baffles. It only handles the reverse flow far-end opening.
- Firebox mount height. It covers a firebox mounted at the lowest point of the chamber, and tells you to add a grease bridge of at least 1.5" there. It doesn't set the mount height off the cooking grate. More on where the firebox mounts: Offset Smoker Sizing.
- Collector box. No collector calculation at all.
- Tuning plates and which side the firebox goes on.
None of that makes it wrong. It was built as a ratio worksheet back in 2011, and it does that job.
How do I check any smoker calculator by hand?
Two checks. That's all it takes.
- The firebox should be about one-third of the cook chamber volume.
- The throat area should be the firebox volume times 0.008.
To get gallons into cubic inches, multiply by 231.
Here's a 250 gallon tank. 250 times 231 is 57,750 cubic inches. A third of that is 19,250 cubic inches of firebox. Times 0.008 is 154 square inches of throat.
If a calculator's firebox and throat land near those numbers for your tank, it's sound. If they don't, that's the thing to look at before you cut anything.
I wrote out the whole sizing order, firebox through stack and collector, with a 250 and a 500 gallon worked step by step: Offset Smoker Sizing: Firebox, Throat, Stack.
If this is your first build, you can follow a full 500 gallon build inside SmokerBuilderU step by step, and bring your sizing questions to the live Q&A every Wednesday night at 7pm Central.
If you'd rather skip the math, every plan set I've drawn is at smokerplans.net, laid out by tank size and fully dimensioned.
PS. Bookmark the real Feldon's link above so you don't land on a copy next time.
Is Feldon's calculator accurate?
Yes. Its firebox size lands inside my best practice range, and it sizes the throat with the same formula I use, firebox volume times 0.008. Where it leaves things out, like the collector box and scoop baffles, it's a simpler tool, and the numbers it does give are sound.
Where do I find the real Feldon's calculator?
On feldoncentral.com, at feldoncentral.com/bbqcalculator.html. The real one carries Morgan Feldon's copyright and credits Alien BBQ and Tom C from TheSmokeRing.com.
What firebox ratio does Feldon's calculator use?
One-third of the cook chamber volume. That's a little above my 0.30 starting point and still inside my range for both offsets and reverse flows.
How does Feldon's calculator size the firebox to cook chamber opening?
Firebox volume in cubic inches times 0.008 gives square inches of opening. You can cut it as a half-moon or slot with the same area instead of a round hole.
Does Feldon's calculator work for a reverse flow smoker?
It covers the far-end opening of a reverse flow, which it sets at least as big as the throat. It doesn't have an option for scoop or vertical baffles.
Do I need a calculator to build a smoker?
No. Check two things by hand: the firebox should be about a third of the cook chamber volume, and the throat should be the firebox volume times 0.008. Multiply gallons by 231 to get cubic inches.
