Door Flanges
Talk about welders and metal working equipment.
hogaboomer
Title: old welder
Door Flanges
Post by hogaboomer » June 21st, 2020, 12:23 pm
These things are a pain! Tack them on the inside, you have to beat them out. Tack or weld them on the outside, you have to beat them down.
What's the best way to put flanges on your doors?
Need to come up with a way to clamp them down so they don't pull so much.
Re: Door Flanges
Post by dacolson » June 21st, 2020, 3:07 pm
I put them on while I’m cutting the door out. Cut a side, weld on a flange. Repeat. Did that on my first build. Kept all of them straight.
Smoking meat - Offset RF Smoker. Big Green Egg. Homemade mailbox cold smoker.
Novice welder - Everlast PowerMTS 252STi
Re: Door Flanges
Post by Dirtytires » June 21st, 2020, 9:01 pm
Can you clamp a bar across the door to keep it from pulling? You could always drill and plug weld or grind a few slots in your flange (and weld them in) so your first welds are more centered. I put small tacks welds on both sides of mine and it worked out nicely.
hogaboomer
Title: old welder
Re: Door Flanges
Post by hogaboomer » June 24th, 2020, 3:50 pm
I saw a guy on Instagram that did the spot weld thing on his flanges, it looks pretty nice. Might be worth a try on the next one.
Re: Door Flanges
Post by dacolson » June 25th, 2020, 8:55 am
I like it. That looks sweet. I need to get a drill press before trying that though. My arm hurts already thinking about drilling all those holes in one go.
andysmoked
Re: Door Flanges
Post by andysmoked » June 26th, 2020, 2:30 am
dacolson wrote:I like it. That looks sweet. I need to get a drill press before trying that though. My arm hurts already thinking about drilling all those holes in one go.
Hell Yes!! A drill press is gold. I’m lucky to have inherited one from my old man.
breavis
Re: Door Flanges
Post by breavis » June 29th, 2020, 6:34 pm
What's the thickness of the door & flat bar you are using? I've practiced on a 55 gallon drum and it seems to be better using thinner metal
hogaboomer
Title: old welder
Re: Door Flanges
Post by hogaboomer » June 29th, 2020, 7:37 pm
The door was 3/8 thick and the flat bar was 1/8. I tweaked the middle of the door on one side trying to bend it in a little, so I had to end up beating the crap out of that one side to get the flange lay down on the cook chamber. I'm gonna try the spot weld deal on the next one I build.
Re: Door Flanges
Post by Dirtytires » June 29th, 2020, 11:38 pm
You might also try 0.25 flat bar. By being closer to the same thickness the two pieces will cool more evenly and maybe not distort as much.
tinspark
Re: Door Flanges
Post by tinspark » June 30th, 2020, 12:14 am
Plug welding seems like a good way to go.(spot welding is typically done with a spot welder in a sheet metal shop- like high school metal shops have)
Plug welding (and spot welding too) should cool evenly on both sides of the metal and pull both ways as it cools
Remember, when a weld is cooling, it is shrinking a little bit.
That's why when you weld from the outside it pulls out (towards the side of the weld) and when you weld from the inside in pulls in.
Plug welding would likely cool evenly on both sides of the metal making for a flatter door.
If you had access to an actual spot welding machine that could handle that thick of material it would also be a very effective way to keep it in shape. but it would definitely be industrial rated and likely have water cooled tongs($$$) in order to disperse the massive amount of heat that would be generated to accomplish that thick of a spot weld, while not damaging (melting) the spot welders tips...... But I think the OP is referring to plug welding as indicated in the photo, which seems like a good way to go also, and could be handled in a home shop...
Plasma cutting the plug weld holes is an alterative to drilling and would save the arm.. I would do that before I rolled the side flanges on a round smoker though.. Holes do not need to be perfect since they will be welded over, but I would make them big enough to grab the base metal.
Regards, Doug Mason
tinspark the chain smoker
the verdict is in: She says "!!Guilty!!
My wife has accused me of being a "Chain smoker", and that I am "addicted to smoking"!!
I admitted to her that I smoke at least 2-12 packs a week !!
(ie. ribs, tri-tip, chicken etc.) !!GUILTY!!---haha! :grillin:
hogaboomer
Title: old welder
Re: Door Flanges
Post by hogaboomer » June 30th, 2020, 2:00 am
Yeah, those door flanges are tricky. This is more the kind of flanges and things I'm used to welding.
Re: Door Flanges
Post by Pete Mazz » June 30th, 2020, 4:43 am
:points: :points: :points:
andysmoked
Re: Door Flanges
Post by andysmoked » June 30th, 2020, 4:45 am
hogaboomer wrote:Yeah, those door flanges are tricky. This is more the kind of flanges and things I'm used to welding.
Wow!! Now that is big welding.
tinspark
Re: Door Flanges
Post by tinspark » June 30th, 2020, 11:22 am
worked in a union sheet metal shop for 34 years (local104) which also had a pipe fitters shop in one of our shop buildings next to ours.
Definitely some awesome welders in your industry. Nice equipment
Love the orbital welder for the cap passes/ looks great!!
Submerged arc? :welder:
hogaboomer
Title: old welder
Re: Door Flanges
Post by hogaboomer » June 30th, 2020, 11:59 am
No orbital, that's all hand welding, except for the sub arc. They are all rollouts, though.
tinspark
Re: Door Flanges
Post by tinspark » June 30th, 2020, 3:12 pm
NIce!!
$$ stainless elbow and flange $$ Chu-ching!!
looks like a TIG root and purge plate on stainless elbow/ flange.
Nice job!!
You using argon purge or nitrogen for your TIG root?
hogaboomer
Title: old welder
Re: Door Flanges
Post by hogaboomer » June 30th, 2020, 3:21 pm
I can't remember on that specific one. We did occasionally use nitrogen to purge, but mostly it was argon. Just depended on what the client wanted. Had two hoses going on that one, takes a lot of gas to fill that big a pipe.
Return to “Welding and Metal Working”
