Double Pan Gravity Feed
Re: Double Pan Gravity Feed
Post by Weldun » May 24th, 2017, 8:14 pm
Nice job on your build. When I put my thermometer in my door I used an o-ring that fit over the threads so it would compress between the nut and the coupling that way I could seal and orient the gauge how I wanted it.
Although my mini gf works fine I built an economical temperature controller for mine, it lacks the fancy bells and whistles but does everything I need and is rock solid for under $75.00 and I am next to technology/electronic illiterate and had no trouble building it.
viewtopic.php?f=102&t=5494#p80215
Post by Squiggle » May 25th, 2017, 6:45 am
Yep, that little gig you made is awesome :kewl:
