Stump's Clone
KarateDoc
Re: Stump's Clone
Post by KarateDoc » July 31st, 2016, 9:32 pm
Well this weekend didn't get a lot done with having to work around the house and the fact that I left my gas valve on and it had a slow leak so I nearly lost all my Argon/CO2. I just had it refilled. :oopssign:
I did get the inside back panel, inside bottom panel, inside top panel, and inside right panel fitted and some tacked in place before I ran out of Argon/CO2.
You can see where I am raising the front up some so I can make a shorter front door and this will raise my slam door latch a few inches higher. Next up will be to get more shielding gas and finish tacking in the panels and flipping it upside down to weld all of the bottom and and put on the outside bottom panel.
Back Panel tacked in
Fire Box test fitted with Right Inside Panel
Side view of Fire Box
https://imageshack.com/i/pl0CAGrjp
Re: Stump's Clone
Post by Rodcrafter » August 1st, 2016, 6:38 am
Re: Stump's Clone
Post by Squiggle » August 6th, 2016, 4:32 am
:LG: :beer:
KarateDoc
Re: Stump's Clone
Post by KarateDoc » August 7th, 2016, 9:46 pm
Only had today to work on the smoker as yesterday was a 3/4 work day and then dinner with the family. Got a lot finished today as I finished up welding the interior except for the shelf racks. Bottom is all welded and exterior bottom plate in place. I opted to use a stainless catch pan for the drain and will use gasket material to seal it. Welded in the entire firebox assembly and so all I have left is to do is the air intake, the last supports, the front door and then insulate it and put the exterior skins on.
Fire Box Welded In Place
Drain Hole
Drain Pan Open
Drain Pan Closed
Entire Fire Box Assembly in Place
Countryboy72
Re: Stump's Clone
Post by Countryboy72 » August 7th, 2016, 10:14 pm
Current smokers :Mak 2 Star General, Double Pan Gravity Feed aka 'Stumps Clone', SS Vertical Propane smoker, Masterbuilt Sportsman Elite Smoker.
Re: Stump's Clone
Post by Tom_Heath » August 7th, 2016, 11:19 pm
Looking good.
Re: Stump's Clone
Post by Pete Mazz » August 8th, 2016, 4:12 am
:yth: :yth:
Re: Stump's Clone
Post by Squiggle » August 8th, 2016, 4:19 am
:LG: :beer:
Re: Stump's Clone
Post by Rodcrafter » August 8th, 2016, 4:24 am
Oh yeah
Re: Stump's Clone
Post by Big T » August 8th, 2016, 8:30 pm
I don't see any pictures, just a black X that says image. :wtf:
Re: Stump's Clone
Post by Tom_Heath » August 8th, 2016, 9:25 pm
Big T wrote:I don't see any pictures, just a black X that says image. :wtf:
Ok, so listen. Once in a while with tap a talk there is a slight issue with pics.
Mainly it happens when the particulate molecules of your available Internet connection become cluttered. This is when the problem starts.
Main symptoms are pics don't show up any more.
Solution, quit letting The czar use your computer to look at dirty pics.
Re: Stump's Clone
Post by Big T » August 8th, 2016, 11:18 pm
He promised that He Wouldn't do that any more !! I guess you can't trust anyone these days.
Re: Stump's Clone
Post by Rodcrafter » August 9th, 2016, 2:01 pm
Poor ole DC!
He just can't catch a break!
Re: Stump's Clone
Post by The Czar » August 10th, 2016, 7:36 pm
Dirty pics...where?
KarateDoc
Re: Stump's Clone
Post by KarateDoc » August 14th, 2016, 9:13 pm
Another short weekend of fabricating. Got the Left Side and Back Panels installed. The Top along with the exhaust stack installed. Racks installed and decided to go with 4 instead of 5 so I have a full 6 inches in between the racks. I may add a few more sliders in later if I decide I need more for ribs or chicken. Started to cut the pieces for the racks then the wife needed the 220 for the drier.
Still waiting for my CyberQ to arrive so I can finish up with Intake. Next weeks plan is to finish the racks, doors and the intake.
Side Panel Installed. Going to put a stainless grab bar/towel hanger on this side.
From View of Racks Installed and 1 frame for the rack.
Re: Stump's Clone
Post by Rodcrafter » August 15th, 2016, 12:49 pm
Re: Stump's Clone
Post by Big T » August 15th, 2016, 10:10 pm
I still don't see any pictures :hissy:
Re: Stump's Clone
Post by Squiggle » August 19th, 2016, 7:47 am
Very cool dude, starting to take shape nicely. :kewl:
Re: Stump's Clone
Post by Tom_Heath » August 20th, 2016, 12:10 am
Looks great.
KarateDoc
Re: Stump's Clone
Post by KarateDoc » August 20th, 2016, 9:34 pm
Had a few hours to work on the racks so welded them up and slid them into place. I may put in three more rack sliders to give me a total of seven so I can do a boat load of chicken quarters and ribs.
I received my CyberQ so I will be working on the air inlets tomorrow and hopefully get it all the external panels in place.
Here are the pics:
Four Racks In Place
Rack Pulled Out
Rack Depth
Rack Width
Rack Spacing
KarateDoc
Re: Stump's Clone
Post by KarateDoc » August 20th, 2016, 9:43 pm
Here are a couple pics of full size catering pans sideways and lengthways.
Catering Pans Sideways
Catering Pans Lengthways
Re: Stump's Clone
Post by Tom_Heath » August 20th, 2016, 10:15 pm
That looks awesome. I love being able to load two pans per shelf. Nice work.
Re: Stump's Clone
Post by Rodcrafter » August 21st, 2016, 7:52 am
Very nice, I did the same and put 7 in mine, I did it mostly for the jerky. It holds a good 25 pounds that way. Image
KarateDoc
Re: Stump's Clone
Post by KarateDoc » August 21st, 2016, 9:22 am
RC, I love to make jerky too but my Traegers just doesn't hold enough so I normally don't make a lot. How far apart are your racks? Can you fit chicken quarters on there? I bought some frog mats that are awesome for doing jerky and smoked salmon. Easy to clean silicone.
Re: Stump's Clone
Post by Rodcrafter » August 21st, 2016, 12:27 pm
Mine are 3-1/2" inches apart I believe, the foil pans fit just right if that helps. I have thought about getting some of those mats to check out.
