Inverted Flame Smoker
mmeagher55
Post by mmeagher55 » July 14th, 2017, 3:39 pm
Hi! Has anyone tried building an "Inverted Flame" smoker? I would like to build a smoker, and have seen one manufacturer of "inverted flame" technology smokers, and the reviews are awesome. Has anyone built one? It would be a clone of the Karubecue smoker, or something with a similar downdraft pull from the firebox to the cook box.
Thanks!
Re: Inverted Flame Smoker
Post by ajfoxy » July 14th, 2017, 10:13 pm
Welcome aboard.
I had a look on youtube (https://www.youtube.com/watch?v=Ag0sM8dIsHg) and it does look interesting. I think without knowing the exact science behind how it works it might be a tad difficult for the home builder. Not impossible, but those guys have obviously put a lot of time and research into getting the thing to work well.
I suppose one could almost say a gravity feed smoker is sort of inverse flame as it takes heat and moves it slightly down and along. But that might be a bit of a stretch. :D
Post by Pete Mazz » July 15th, 2017, 3:53 am
Seems more complicated than it needs to be. I would be concerned about longevity. All that heated, moisture laden smoke has to be tough on moving parts. I agree that a GF is a much simpler concept and can run all day and night with just one feeding.
Post by Rodcrafter » July 15th, 2017, 6:45 am
Welcome to the crew!
Post by Squiggle » July 16th, 2017, 1:51 am
:welcome: +1 for the simplicity of a GF. :kewl:
mmeagher55
Post by mmeagher55 » July 17th, 2017, 10:32 pm
A GF would definitely be easier to build. Plus, you don't have to babysit them feeding fuel. How much are the GFs to build with sheet metal and parts?
Thanks for the kind responses!
Post by Squiggle » July 18th, 2017, 6:40 am
I spent about $1200AUS, I think most have gotten away with around $900USD. :kewl:
Post by Rodcrafter » July 18th, 2017, 12:31 pm
That sounds about right. One advantage is you will never have to replace any motors or stuff like the other. Now I use a CyberQ to run my GF but some others don't, it's not required. I only mention that because it has a fan motor.
Post by Big T » July 18th, 2017, 6:47 pm
That looks like a pretty complex system, I certainly don't think I could build one.
