Double Pan Gravity Feed
Re: Double Pan Gravity Feed
Post by Tom_Heath » August 7th, 2016, 7:48 pm
I am not sure why the tubing for the door is less then the main framework. I will see what I can find out. I happen to know where frank lives in the event that I can't get ahold of him. LOL
Countryboy72
Post by Countryboy72 » August 7th, 2016, 10:07 pm
Thanks Tom. I sent him a PM too, guess he's really busy right now.
Current smokers :Mak 2 Star General, Double Pan Gravity Feed aka 'Stumps Clone', SS Vertical Propane smoker, Masterbuilt Sportsman Elite Smoker.
Post by Tom_Heath » August 7th, 2016, 11:21 pm
He is, work is killing him. Worst case I will discuss it with him this coming weekend and post back. I know I can get him cornered as we have other business to go over. Well and maybe drink a beer also.
Countryboy72
Post by Countryboy72 » August 9th, 2016, 3:57 am
Anybody know how long it would take someone to create CUT FILES for the DPGF smoker, from the drawings ?
KarateDoc
Post by KarateDoc » August 9th, 2016, 7:17 am
I just did my own from each page. Figured what I could build and purchased it in stages.
Post by Tom_Heath » August 9th, 2016, 1:33 pm
So the honest answer for the door tubing actually makes no difference since it's a surface mount door. 1.5 or 2 inch will work fine. Spoke with Frank this morning about it.
Countryboy72
Post by Countryboy72 » August 9th, 2016, 3:52 pm
Awesome, thanks Tom
raptorchris
Post by raptorchris » August 17th, 2016, 11:17 am
I ran into the same issue with 1 3/4" not being availabl . I talked to Frank and either 1 1/2" or 2" is acceptable. I went with 2". That way I only needed 1 size of insulation. It will slightly affect both the firebox and coal fill doors. The heights of the chute will be slightlyshort. I just welded it sealed, as it ddoesn'taactually effect anything.
Countryboy72
Post by Countryboy72 » August 26th, 2016, 2:05 pm
Went an saw the welder/neighbor today :) He's going to order the metal and get started. One question I have is I am seeing alot of guys spot welding and stitch welding. I am going with thicker walled square tubing and heavier guage sheet metal for this build. Are the inside and outside metal walls fully welded, spot,or stitch welded permanently into place ?
Post by Squiggle » August 26th, 2016, 3:36 pm
The reason people spot/stitch/tack weld it to reduce warping. I have been tacking every 2-3in, then come back over & weld every third or fourth gap until I have welded the whole edge/join to spread the heat more evenly. :beer:
Countryboy72
Post by Countryboy72 » August 27th, 2016, 1:51 am
Squiggle, Thanks. That is what i figured. The welder will do what he thinks will work best, i am sure. Going with heavier metal should make it a little easier for him to weld, less likely to get heat warpage if he's careful. I told him its fully welded :) Does anyone know if the kit from BSS will work with the double pan GF smoker ? Any where else to order latches and gaskets from ?
Post by Squiggle » August 27th, 2016, 6:07 am
I believe BSS is a sister site to this one & it's owned by the same guys(correct me if I'm wrong Frank) & the kits are designed to suit all the plans(another sister site to this one) :kewl:
Post by Dirtytires » August 27th, 2016, 10:20 am
I couldn't find descent gaskets anywhere else and the prices are pretty fair on the bss page. I checked out grainger for latches as well...same style of latches but in some different configurations.
Post by Frank_Cox » August 27th, 2016, 7:39 pm
Squiggle wrote:I believe BSS is a sister site to this one & it's owned by the same guys(correct me if I'm wrong Frank) & the kits are designed to suit all the plans(another sister site to this one) :kewl:
Actually we used to own it. We sold it to Justin Martin of island outdoor a couple years ago. We work very closely with Justin on that site and many others. Smokerbuilder Manufacturing makes Most of the iron parts he sells
Countryboy72
Post by Countryboy72 » August 28th, 2016, 1:32 am
BSS emailed me today, they will make me up a custom kit. I don't want the tie down rings. I want a different thermometer, one that is threaded.
Post by Squiggle » August 28th, 2016, 3:42 am
Thanks Frank, I knew you & the guys had a hand in it somewhere, lol. :D
Countryboy72
Post by Countryboy72 » October 22nd, 2016, 5:47 pm
An so it begins. The welder has the firebox, charcoal chute, c channel all welded up. He just needs to weld the three together. He gave me some of the square tubing to insulate as well :) I will try to get some pictures of the other pieces on Monday, when i drop the insulated square tubing off.
Post by Rodcrafter » October 22nd, 2016, 6:28 pm
And here goes another sweet build.
Post by Squiggle » October 22nd, 2016, 6:55 pm
:yth: can't wait to watch this one grow. :beer: :kewl:
Post by Tom_Heath » October 22nd, 2016, 7:50 pm
I would love to have a gravity feed again but I just don't want the weight.
Post by Squiggle » October 22nd, 2016, 9:07 pm
I don't want my weight either, but that has nothing to do with my GF........or maybe it does. :D
Countryboy72
Post by Countryboy72 » November 19th, 2016, 7:07 pm
Post by Squiggle » November 20th, 2016, 12:13 am
Fantastic work dude, looks awesome! :beer: :kewl:
Post by Rodcrafter » November 20th, 2016, 9:39 am
Oh yeah
KarateDoc
Post by KarateDoc » November 20th, 2016, 12:40 pm
Been there done that and now I am cooking! You will love it
