Stump's Clone
Re: Stump's Clone
Post by Squiggle » October 23rd, 2016, 6:57 pm
Looks awesome! I bet you can almost taste it too. :beer:
Re: Stump's Clone
Post by ajfoxy » October 24th, 2016, 4:13 am
Nice, very, very nice.
:beer:
Re: Stump's Clone
Post by Rodcrafter » October 24th, 2016, 5:54 am
At this point I'm with Tom I want one too. Nice job!
Re: Stump's Clone
Post by mp4 » October 24th, 2016, 6:27 am
That looks AWESOME!
Smokenblues
BBQ Comp Team Name: Smoke 'n Blues BBQ
Not competing yet..
Re: Stump's Clone
Post by Smokenblues » October 24th, 2016, 9:13 am
Man that looks incredible. Great job!
Sent from my Samsung Galaxy S7 using Tapatalk
Currently smoking on:
55 gal UDS
30"×60" RF trailer mounted stick burner
holyp
Re: Stump's Clone
Post by holyp » October 27th, 2016, 3:12 pm
Very nice, now you can kick someone's butt, heal them, and serve them a perfectly smoked meal. The full treatment
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 6th, 2016, 9:06 pm
Well guys, today I had the time to fire up the BBQ and begin the seasoning process.
Started by filling the chamber up about 1/2 way with about 1/2 a bag of some Kingsford Blue that I had laying around for about 10 years. Just in case I bought some new bags of Kingsford Blue and a bag of Cowboy Lump as that was what was available at the local store and we were out shopping. Starting temperature was at 70 degrees.
Used a propane torch to get it going and then hooked up the CyberQ with a Pit Viper fan to bring it up to 275 degrees. Once it hit about 100 and the inside stopped sweating I coated the whole thing with vegetable oil and closed her up it took almost an hour to get to 275 but I had the cook chamber open for about 20 minutes. I have it keeping steady at 275 and the Pit Viper fan is running about 50%. Will try next time to see how long it will take to get up to temperature. If it is too slow I will get the larger fan or use some sort of forced air through the 2" ball valve.
Will see how long it lasts with this much charcoal in the chute. I will report back on how long the heat lasts cooking at 275. Next will be to clean the cook chamber after it cools down and then to do a test cook on it.
Starting Temp
Cyber Q
We have Smoke!!!
Re: Stump's Clone
Post by temurf » November 6th, 2016, 10:19 pm
:LG: :beer: :kewl:
Really sweet looking setup you have built there Doc. Awesome job.
Re: Stump's Clone
Post by Big T » November 6th, 2016, 11:01 pm
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 7th, 2016, 8:58 am
Started recording temperatures at 3:33pm and once I finished seasoning the cook chamber I closed the door 4:12pm and never opened it again. Once the smoker hit temperature of 275 degrees 4:58pm it held steady for 8.5 hours before it started to decline.
Then the temperature started to fall:
273 degrees in the first hour
262 by the second hour
246 degrees in the third hour
212 by the fourth hour
I shut it down after that.
shortlived
Re: Stump's Clone
Post by shortlived » November 7th, 2016, 11:17 am
Looks awesome! So 8+ hours on 10 lbs of charcoal? Not bad at all. I'm curious to see if running your blower in the 2" line will help get temps higher. I'm about to pull the trigger on this and wondering if I should just order the bigger blower. FYI thank you for all of the great pictures of your build.
forty_creek
Title: 40 Ways 2 Kansas
Re: Stump's Clone
Post by forty_creek » November 7th, 2016, 7:04 pm
Strong Work KaratDoc
DRANKIN, SMOKIN and DREAMIN
Re: Stump's Clone
Post by Squiggle » November 7th, 2016, 7:14 pm
:LG: very nice work doc, well done! :kewl: :beer:
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 8th, 2016, 2:04 am
Shortlived - I could program the temp higher and will do some more testing in the near future. Most of my cooks are at 275 and below so I wanted to see how it would perform as a first test. Since everything seems to check out I will turn up the heat. Would a larger fan work out? Probably but will see how this works out.
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 12th, 2016, 9:03 pm
Today is the first cook and I am doing 20 chicken quarters. Took almost two hours to get it up to 300 degrees and after I put the chicken in it is taking forever to get back up to temp with the pit viper fan. I think I am going to order the larger fan and also the run it with duals to see if I can get it to get up to cooking temp faster and to return once the door is open.
Will post up pics when I am done cooking.
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 12th, 2016, 10:26 pm
Okay not so stellar results. :headwall:
Had the probe in the meat and it wasn't reading properly. Showed 130 and after 1 hour of cooking I went out and probed it with my handheld and it was at 200 :huh:
Well pulled them mighty quick and let them rest. While they look good and taste is okay, they cam off the bone well but was dry.
Will have to monitor the meat better and see what else I can do next time. Not bad for the first cook and can improve.
Tomorrow it is a ribeye roast testing out the rotisserie. Wife and I like our meat medium well so you won't like those pics :p
Re: Stump's Clone
Post by Squiggle » November 13th, 2016, 2:27 am
I always leave the side door open to bring it back up to temp, usually takes a few minutes. :beer:
Chicken looks good, can't wait to see the ribeye! :kewl:
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 13th, 2016, 8:52 am
Good to know Squiggle. I will try that today.
Re: Stump's Clone
Post by Rodcrafter » November 13th, 2016, 9:21 am
Nice Q
Re: Stump's Clone
Post by Tom_Heath » November 13th, 2016, 10:29 am
I find it really difficult to probe chickens.
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 13th, 2016, 6:41 pm
I decided to use my old ThermoPro TP08 and compare that to the CyberQ and the River Country Thermometer in the door. The Cyber Q reads 19-23 degrees higher than the other two. So I deceide to bumpp up the temperature up by 25 degrees
At the moment I am using the rotisserie function and cooking the Rib Roast and some baked potatoes.
Will see how it all comes out later.
Squiggle - The tip you gave me about opening up the side door helped get the temps back up quickly. :kewl:
Pics and video to come later.
Re: Stump's Clone
Post by Squiggle » November 13th, 2016, 9:18 pm
Only too happy to help, glad it worked for ya. :kewl:
KarateDoc
Re: Stump's Clone
Post by KarateDoc » November 13th, 2016, 10:01 pm
Pics or it didn't happen? Well here they are!
Here is a video of the rotisserie in action!
https://youtu.be/D9iiuIdQ2H0
shortlived
Re: Stump's Clone
Post by shortlived » November 13th, 2016, 10:36 pm
Damn it now i have to add a rotisserie to the plans! Looking great.
Smokenblues
Not competing yet..
Re: Stump's Clone
Post by Smokenblues » November 13th, 2016, 11:03 pm
Definitely going to add a rotisserie to my build a well!
55 gal UDS
