Double pan Insulated cabinet Gravity feed
holyp
Post by holyp » May 29th, 2016, 4:03 pm
Hi everyone,
After several months of research, I came to the conclusion that an insulated cabinet gravity feed is the smoker i want to have.
The possibility of having hours of consistent cooking unattended sold me on the design.
That, and the fact that teams with GF cookers win competitions hopefully means the flavor is still there.
As I'm located in Israel, and I just can't call Stump and ask him to send me a smoker I found smokerPlans.net and got the plans fo the double pan. Next I ordered everything on the list, and got a nice bag of goodies by mail
Posted a question in my 4*4 forum about converting the plans from inches to metric, and got an offer to do the conversion and fabrication and since i have no knowledge, experience or time we settled on a fair price and the journy began.
Insulated the inside of the frame with regular rock wool (for the cabinet, and fire chamber area I got ceramic blankt which is rated at a super high temp)
Frame is begining to take shape
Inside skin
Starting work on the coal chute
Removable fire grate
This is the thickest section (12 MM nearly 1/2 an inch), was a pain to cut
Chute nearly done, super heavy
Looking forward to comments, feedback, suggestions
Thanks,
Amir
Smurf
Title: Lets all have fun
Re: Double pan Insulated cabinet Gravity feed
Post by Smurf » May 29th, 2016, 5:57 pm
Looks like your off and running. :beer:
Post by Weldun » May 29th, 2016, 9:43 pm
Welcome and build is looking good.
Post by Big T » May 29th, 2016, 11:20 pm
Post by Pete Mazz » May 30th, 2016, 3:58 am
Welcome! Looking good!
Post by Rodcrafter » May 30th, 2016, 6:37 am
The build is looking great I'm excited for you. That is one big smoker when you're done. I only have one question, what is the gap between the bars on the fire grate? It looks like they're too far apart to me.
Not being critical just trying to help
Post by Squiggle » May 30th, 2016, 7:09 am
Wicked dude, looks very cool! :beer:
I have a question too, I think you are meant to leave to top rail off so you can install the FB, just wondering how you will install it with the rail there? :?
holyp
Post by holyp » May 30th, 2016, 10:52 am
Hey Rod crafter, good catch. The gap is just over an inch and while the double pan plans don't specify this, the plans for the single pan do. And the gap is meant to be half an inch, so I have some fixin to do.
(edit:fixed :lol:)
And Squiggle, that's how the plans for the double pan specify it, unlike the single pan where it specifies to leave out 4 pieces in the double pan it mentions only three. Possibly because it's taller so you don't have a problem Hope it works out.
And thanks for the feedback, I dropped by today and I must admit it's bigger then I imagined...
Sweet.
holyp
Post by holyp » May 30th, 2016, 12:52 pm
I just looked at the mini plans again and I see that for the mini it specifies 4 pieces not to install. For the double pan it just mentions 3 to install after the fb. The cross member and two small vertical pieces
Post by Squiggle » May 31st, 2016, 6:15 am
Ok, I was just thinking that if you have to insert the FB into the transfer tube opening in the side wall, & the chute is higher than the top rail, it might be a bit difficult. I even left out the front corner upright to make it easier to slide the FB in with the ball valve pipe installed. :kewl:
holyp
Post by holyp » May 31st, 2016, 8:03 am
Made some more progress today.
Heat and smoke transfer tube
Firebox and chute in placs
Post by Rodcrafter » May 31st, 2016, 9:38 am
Now you're talking, good work
SmokinHawgBBQ
BBQ Comp Team Name: Madmikes Smokin Hawg BBQ
KCBS Judge
Always lookin for guys to join the team !
Post by SmokinHawgBBQ » May 31st, 2016, 1:29 pm
Lookin Good!!!
Mike B-)
NEVER MET A PIG I DIDN'T LIKE
Post by Squiggle » May 31st, 2016, 7:18 pm
Awesome stuff, looks fantastic! :beer:
Post by Big T » May 31st, 2016, 9:16 pm
It's really coming together :beer:
holyp
Post by holyp » June 26th, 2016, 2:53 pm
Wow things are never moving as fast as you want them.
The skins are on with insulation. Ran through way more material than I had expected, I used ceramic wool rated at 2600 degrees (Fahrenheit). Probably an overkill, but this whole smoker is a bit of an overkill, why stop at insulation.
I already had it on wheels, but one of them gave already... it was meant to be rated 250 lbs
Sent from my Nexus 10 using Tapatalk
Post by Pete Mazz » June 26th, 2016, 3:44 pm
Those buggers sure get heavy!
Post by Big T » June 26th, 2016, 8:16 pm
I remember when Puff built his big GF and all he talked about was how heavy that joker was. You've definitely got it going your way now :kewl:
Post by Rodcrafter » June 27th, 2016, 7:49 am
The double pan GF will weigh 800 + lbs. So you need wheels that good for half that each.
holyp
Post by holyp » June 27th, 2016, 3:42 pm
Picked up the meat racks today. Found an 80 fabricator to do it for me as his last job before retiring again.
Got 5 racks from stainless steel 6 mm (just under quarter inch).
Cost me just over 300 dollars which I think is a great buy.
As for the wheels, they were rated at a 100kg each which is 220 lbs so I should have been OK.
Anyways the guys at the store were nice enough to offer replacement at no charge, and I ended up taking 8 inch casters super duty rated at a 1000lbs each, so I should be covered
Post by Rodcrafter » June 27th, 2016, 5:54 pm
That's a nice bunch of racks, and you won't regret those wheels either
Post by Pete Mazz » June 27th, 2016, 6:00 pm
I agree!!
Post by Big T » June 27th, 2016, 8:06 pm
:yth: Super nice racks :kewl:
holyp
Post by holyp » July 10th, 2016, 4:00 am
Finally finished with the insulation. Stuffed the area around the coal chute as much as possible
Sealed the top and added the door
Got the side door done
Now to the main cc door and rails.
Post by Pete Mazz » July 10th, 2016, 4:22 am
:beer: :beer: :beer:
