Another Mini Gravity Feed
- pr0wlunwoof
- Expert
- Richb
- Just Got in trouble for buying tools
- Title: Member
Re: Another Mini Gravity Feed
I used a dimple die to punch out a hole. The punch also rolls the edge inward. I then just welded the punched out piece back into the now countersunk rolled edge.
Richb
Current smokers, Mini Gravity Feed Smoker (just finished building), Cookshack electric smoker, And a Charbroil Offset Smoker.
- pr0wlunwoof
- Expert
Love the technique. Wish I could justify the cost of the punch tool. Some others suggested a 1/2 collar and I picked one up for $2. Gotta say though your recessed thermometer looks very legit.
- SmokerBuilder Addict
- Title: Member
- BBQ Comp Team Name: Not competing yet, Family and Friends!
- Richb
- Title: Member
Thanks. It was well worth it. Plus now I can do awesome smoked meats. This smoker works beautifully. So glad I went with these plans.
Richb
- Frank_Cox
- Site Admin
- Title: OB1
- BBQ Comp Team Name: Team SmokerBuilder- Competition BBQ Team
KCBS Cert. BBQ Judge - Location: Missouri
- Contact:
Re: RE: Re: Another Mini Gravity Feed
Awesome buddy, got one more mod to make to it and test it then we will start the plansRichb wrote:
Oh!! and for Frank, when you get the plans for the "Hawg Cawfin" done. I'm all over them too.
- has a junk pile that will one day smoke LOTS of BBQ
How's the powder coating holding up?
Talked to a powder coater locally about cost and his price was pretty reasonable. ..
Not sure how durable the plastic Finnish and heat would play nice together...
- Richb
- Title: Member
The coating around the firebox has darkened. There is hairline checking around the other areas that gets hotter than you would want to touch. You have to get in really close to see them but they are there. Other than that it is holding up nicely. I think the coating around the firebox will continue to get darker. I’m just not sure how dark it will get.
Richb
Bummer on the darkening...
Perhaps a piece of decorative diamond plate around/over area so it's not so unattractive. ...
- Richb
- Title: Member
It doesn’t look that bad. It looks kind of like darkening from smoke. So I can live with it.
Richb
- ajfoxy
- Expert
- Title: Neophyte Smoker Bldr
Think of it as a smoke ring on your smoker...
- Newbie
Do you remember what you cost of goods was? I know the labor is priceless.
- Richb
- Title: Member
I figured with the powder coating included it cost me just over $2200.00. Plus towards the end of the build I was not looking for the best price for parts. I was just getting whatever was most convenient and quick to receive.
Richb
- beginner
Love the turn out on your smoker.
What type and where did you purchase the installation you used?
And how much would you recommend buying. I seen you ran out part of the way through.
I'll be starting my mini build today.
- Senior SmokerBuilder
- BBQ Comp Team Name: Smoking and building in the UK.
How do you remove the drip tray if it has a ball valve attached? Do you unscrew the valve and lift up inside?
- Richb
- Title: Member
The drip tray just funnels to the drain valve. It is not attached to the valve.
Richb
Does the drip tray have a sleeve that goes into the valve spigot or does the grass just seep under the drip tray?
- Richb
- Title: Member
I used a dimple die to punch a hole that lines up with the valve.
Richb
Well I've got mine completed at last. I would post some pics but it's such a ballache to do that here as they have to be uploaded to a host first. Still, I cooked some baby backs at work for the guys and they loved them.
- Dirtytires
- Expert
- Title: It ain't broke...yet
Congrats on finishing.
Pictures are actually pretty easy to load. You just have to use the ‘full editor & preview’ button then find the file on your computer and hit submit. Would be happy to walk you thru it if you need.
I don't have a pc anymore. Other forums I use I can upload straight from my phone. Never mind main thing is it's done. Now to get to some cooking. BV,
- Dirtytires
- Expert
You can upload directly from your phone or tablet as well.....sorry you are having trouble.
