? on Wood types and moisture content
Discussion about Woods for smoking
mag1
Post by mag1 » July 17th, 2014, 7:44 am
Ok, I'll be finishing up my smoker soon. What I want to know is what types of wood should I use to fire it? The wood we have available in the area that I can get easily are: Oak, Hickory, Maple, apple, then just plain old campfire wood (poplar, pine, ect.....) I know you should use nut/fruit trees.
Can you use maple? There is a wood processing place about 15mile from me that has mixed oak/maple/Ash for $30/face cord. I can sort the oak/maple out, but can you use ash? not sure what it would smell like. (I could sort the ash for the fire pit for a relaxing evening fire)
I also have access to some apple, I'm going to snag that.
Mosture - do you want the wood seasoned, or to have some mositure in it? (dry or damp or somewhere in between?)
thanks, I'm a newbe to all of this.
Re: ? on Wood types and moisture content
Post by The Czar » July 17th, 2014, 8:23 am
Maple is fine.....seasoned and dry wood is preferred
DUAYNE B
Post by DUAYNE B » July 17th, 2014, 4:46 pm
Heck, everything you mentioned is perfect smoking wood..,,,, stay away from any of the pines... you do not want that near your smoker. all the other woods you mentioned are perfect
Post by Rodcrafter » July 17th, 2014, 8:21 pm
Yep and welcome to the crew
Post by Puff » July 18th, 2014, 12:06 am
Like a wood stove, you will want to avoid creosote with un-seasoned wood
Post by Gizmo » July 18th, 2014, 6:58 am
Give the ash at least a couple months (6 is better on all of it but the hickory) after splitting it - green ash is a weird flavor …. local restaurant uses it and a buddy of mine supplies them - that's what I've learned about it. :D
mag1
Post by mag1 » July 18th, 2014, 7:48 am
Thanks guys, you all have been a big help, we are going to try and have my smoker done other than painting by next friday. so..... I need to see what kind of wood I need to find. :)
jasonz
Post by jasonz » July 19th, 2014, 3:27 pm
Gizmo - how long do you give hickory? I got some pignut hickory that was cut and split about a month ago.
Post by Gizmo » July 19th, 2014, 8:26 pm
About 20 minutes - or one refreshment.
I think Hickory is the only wood you can cut and burn immediately without a "green" flavor. It seams to burn a little hotter after a few months being split but otherwise you're fine.
I've never heard the term pignut hickory so I can't help you there.
Can you tell us more about it? :D
jasonz
Post by jasonz » July 20th, 2014, 8:02 pm
Not much - lol. 2 days ago, i scored some. All i know about it is when asked what kind of wood is that - the guy said pignut hickory, ill cut you all you want. Yea i can use that, took what he had, and made sure not to lose that number. He also has a ton of cherry and oak. Im happy.
Post by Puff » July 20th, 2014, 8:23 pm
Hmm! Check this out on pignut hickory
http://youtu.be/OhDZXbaSWvY
Post by Gizmo » July 21st, 2014, 6:43 am
Thanks!
Miketheforester
Post by Miketheforester » July 21st, 2014, 9:26 pm
I really like to season any wood I use to at least 6 months, it will get you a more consistent burn. Also I have not found much difference between the hickories, they're all good. However, I do use green wood blocks in UDS's and other non stick burners.
SmokinFF
Post by SmokinFF » July 22nd, 2014, 11:08 am
I've used green wood blocks too Mike, but I've found the paint puts off a funny flavor. :oopssign:
Post by Puff » July 22nd, 2014, 12:58 pm
After the second read :headwall: oh my!
jasonz
Post by jasonz » July 29th, 2014, 3:04 pm
I picked up a $30 wood moisture meter. That month old pignut hickroy I scored was split into firewood (after it was cut) into probably 16" by about two fists. Last weekend I split a split. The inside moisture was 43%, outside was 17%. This past weekend I split that split again, the inside moisture was 23% and outside 17%. The ribs I cooked on Sunday tasted great. Thanks Gizmo!
Post by Gizmo » July 29th, 2014, 5:30 pm
No problem!
Get your hands on a little of that cherry - a lot of the pros swear by that stuff.
Partial to peach myself…. :D
Grabber70Mach
Post by Grabber70Mach » July 30th, 2014, 8:46 am
What about Plum?
From infinity and beyond
Pennywise
Title: Bearded Wonder
BBQ Comp Team Name: WMD BBQ
Post by Pennywise » July 30th, 2014, 9:47 am
I think the rule of thumb is ANY fruit wood is good smoking wood Grabber.
Grabber70Mach
Post by Grabber70Mach » July 30th, 2014, 10:04 am
Pennywise wrote:I think the rule of thumb is ANY fruit wood is good smoking wood Grabber.
Thanks
SoloQue
Post by SoloQue » July 30th, 2014, 3:33 pm
Quick weigh-in as I found the exception to frujit wood. I was convinced that Persimmon smelled good when it was cut so it would make a good smoke. Wrong .... Wrong ... did I mention I was WRONG. Persimmon while yes it is a fruit tree will get bitter and overpowering quick. I had some good runs where I was blending and probably posted on here about the success but in the long run I discovered that ... on its own ... Persimmon just is not up to the task. I ruined about $300 worth of Butts I was smoking for a buddy's fund raiser. Now I am consuming what is left as a starter wood since it does burn fairly quickly. For anyone who spoke up and told me they thought Persimmon was bitter ... I yield to the truth. Sadly I think it was the Czar who spoke up but I will hold off on confirming that :-B
Post by The Czar » July 31st, 2014, 1:50 am
Plum is good....like grape it first smells horrible but tapers out quick and works good
Return to “Wood”
