Shielding gas or not?
TheBigToe
Title: Let me at it...
BBQ Comp Team Name: Don't compete
Post by TheBigToe » March 19th, 2019, 11:37 am
I have a Hobart Handler 140 I picked up at a pawn shop. It didnt have the gas regulator or shielding gas bottle. Looking for input on purchasing a regulator, hose and bottle or simply continuing to used flux wire.
Re: Shielding gas or not?
Post by JKalchik » March 19th, 2019, 12:17 pm
Some place like Tractor Supply, one of the fleet farm stores, your local welding supply, Or online like CyberWeld.com.
Flux core isn't necessarily bad, useful when welding in a breeze that would blow away the shielding gas.
TheBigToe
Post by TheBigToe » March 19th, 2019, 2:54 pm
Just didnt know if it was worth the $100 for the regulator and hose setup
Overspray
Post by Overspray » March 19th, 2019, 4:14 pm
IMO, it would be worth the $100. Flux core will glue it together, but using shielding gas will get you cleaner welds with less hassle.
Post by Big T » March 19th, 2019, 7:22 pm
Post by Dirtytires » March 19th, 2019, 7:33 pm
Double yea that.
I absolutely hate flux core. You will find the gas produces a nicer weld and the splatter is decreased greatly.
A bottle of gas will last a fair amount of time but bigger bottles aren’t much more to fill than the smaller ones. I run two 80cuft bottles so I always have a full one. Most places like airgas will let you change up/down on bottle size by just paying/refunding the difference in case you ever want to switch.
Post by Chromeski » March 19th, 2019, 10:17 pm
I agree with DT. I recently bought a second bottle because you just can't run out at a good time.
DunnSmoke
Post by DunnSmoke » March 20th, 2019, 6:00 am
I use C02 on my Hobart 140.
You can find a 20 lb C02 bottle cheap. They are the ones used on the fountain drink machines.
I will never go back to flux core.
Im a novice and only weld a little.
TheBigToe
Post by TheBigToe » March 20th, 2019, 11:34 am
So co2 is better than argon?
Diggerg
Post by Diggerg » March 20th, 2019, 1:51 pm
I personally wouldn't waste argon on MIG. Maybe a co2 argon mix but I keep the pure argon for Tig stuff
DunnSmoke
Post by DunnSmoke » March 20th, 2019, 5:10 pm
CO2 is not better than argon, just a lot cheaper.
I agree with Diggerg.
Post by JKalchik » March 20th, 2019, 6:02 pm
Gas depends on both process and metals.
I've got 2 bottles in the garage for the MIG for mild steel and stainless, as well as another for TIG.
Post by Big T » March 20th, 2019, 8:00 pm
I use c25 for welding carbon steel, it's pretty cheap and does a good job.
Post by Dirtytires » March 20th, 2019, 8:40 pm
I started with co2 and keep a bottle around as i find it better for welding outside. For the shop, I keep the 25% co2 /75% argon mix. On my last exchange, I gave $38 for a 80cuft cylinder.
TheBigToe
Post by TheBigToe » March 22nd, 2019, 3:29 pm
Thanks for the input.
