Cold smoking on a Double Pan Gravity Fed
hannibalsmith63
Post by hannibalsmith63 » May 20th, 2018, 7:51 pm
Would it be possible to cold smoke on the DP without anything in the chute and feeding cold smoke through either of the ball valves? Love to hear thought from the group.
James
Current smokers: Pitboss K24, Char griller offset, DP Gravity Fed Stumps clone, and a Cheap Bradley in the garage somewhere! Oh, and a La Caja China Pig Roaster....
Re: Cold smoking on a Double Pan Gravity Fed
Post by Rodcrafter » May 20th, 2018, 8:34 pm
Sure you could and even one of those maze rascals that burn sawdust.
Post by Big T » May 20th, 2018, 9:31 pm
Heatermeter builder
Post by Heatermeter builder » May 21st, 2018, 1:44 am
Get a new soldering iron and a coffee can. Fill it with wood chips of your choice and make a hole small enough to insert the soldering iron in and route the cord through the ball valve. You might have to close down the outlet some
hannibalsmith63
Post by hannibalsmith63 » May 21st, 2018, 6:41 pm
Heatermeter builder wrote:Get a new soldering iron and a coffee can. Fill it with wood chips of your choice and make a hole small enough to insert the soldering iron in and route the cord through the ball valve. You might have to close down the outlet some
Good idea...
tnorthern
Post by tnorthern » May 31st, 2018, 9:47 am
I use an Amazen with pellets, you can cold smoke in anything that you can control the airflow in. Heck some guys just use a big cardboard box...
Here's some bacon and cheese from this weekend. ImageImage
Sent from my Pixel 2 XL using Tapatalk
Post by Rodcrafter » June 1st, 2018, 5:43 am
:beer: :LG: :beer:
Post by Big T » June 1st, 2018, 11:16 pm
:yth: :needfood:
Post by Frank_Cox » June 2nd, 2018, 9:52 am
Heck yeah!
I have been known to use a cardboard shoe box and a cooling rack....
McBroom
Post by McBroom » June 2nd, 2018, 9:55 am
Lol great idea
I Love My 2018 RAM 2500HD 4x4 Off Road 6.4L. USMC (ret)
Post by Weldun » June 2nd, 2018, 7:18 pm
I made some snack sticks using low temp smoking last weekend and used one of those amazin pellet trays for my smoke source, I lit both ends and had plenty of smoke. I used my temperature control for ventilation and worked pretty darned good.
Post by Rodcrafter » June 3rd, 2018, 6:54 am
Now that’s using it
