Mini Gravity Feed.
Re: Mini Gravity Feed.
Post by JKalchik » May 8th, 2018, 7:18 am
@Rodcrafter..... I am just incredibly spoiled by my g/f (20+ years this time around.... but that's a story for a tasty beverage or three....) she got me hooked on home brewing, I now have a 4 tap kegerator in the media room. And she's quite happy that I'm starting on this smoker project although she put the serious kibosh on the 250 gallon propane tank conversion. Truth be told.... I think I'm gonna be happier with this one anyway.
pr0wlunwoof
Post by pr0wlunwoof » May 8th, 2018, 7:27 am
I too homebrew. Dual tap kegerator. Wine and beer. If the feds will legalize it I would make small batch bourbon.
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 7:30 am
Started putting the hardware on and the cook chamber door wont shut flush with the gasket. Gotta put the bar clamps on and readjust the bullet hinges. :hissy:
Post by JKalchik » May 9th, 2018, 7:57 am
<pulls up a chair> Crud. That's something that makes me nervous. And you just put that purty coat of paint on.
Gotta be noon somewhere. I'd offer you a tasty beverage... or would that potentially make things worse? :)
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 9:17 am
Is what it is. Rather deal with it now.
Post by JKalchik » May 9th, 2018, 10:19 am
I have to ask, how is it out of alignment? is the door twisted out of plane? Is an edge lifted?
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 10:59 am
The gasket is too thick. Creates a wedge when trying to close so one side seals and the other is loose.
Post by JKalchik » May 9th, 2018, 11:16 am
Ah.... Common wisdom here I thought was to use a 1/8" spacer before welding on the doors. I haven't looked closely at the gaskets I have (large parts kit from BBQ Supply.) I guess alternatively I could apply the gaskets & clamp them down before mounting the hinges, but paint becomes problematic.
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 11:19 am
I used a spacer but it must not have been thick enough. It won't take long to fix just another thing to do.
Post by JKalchik » May 9th, 2018, 11:49 am
<scratches head> Maybe..... at least on the cook chamber door, affix the gasket with painter's tape to the body and compress it down with bar clamps. That'd be not too horribly hard. That'd be more of a problem with the firebox door and the charcoal chute door, though, there's no good way to get a good even clamp around the door.
Don't mind me, I'm just leaving brain droppings. And commiserating. I'm gonna try to not have to cut anything apart and put it back together when I'm building mine.
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 1:21 pm
That's the plan. Bit of an issue with the other doors but the latch compresses everything enough. The slam latch just doesn't have enough resistance to make the cook chamber seal to my satisfaction
Heatermeter builder
Post by Heatermeter builder » May 9th, 2018, 3:39 pm
pr0wlunwoof wrote:That's the plan. Bit of an issue with the other doors but the latch compresses everything enough. The slam latch just doesn't have enough resistance to make the cook chamber seal to my satisfaction
I added a latch to the top of my Gf, as I have a similar situation. It seals the door very nicely now. When I can get around to it,I will redo the door but for now I'm happy with it.
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 3:47 pm
I contemplated an additional latch, but I dont want to mess with it much after I call it done.
Post by Rodcrafter » May 9th, 2018, 6:51 pm
If you used 1/4” gasket put 1/8” on it instead.
pr0wlunwoof
Post by pr0wlunwoof » May 9th, 2018, 7:56 pm
Sorted it for nowImageImageImageImageImageImage
Post by Big T » May 9th, 2018, 8:55 pm
Heck yeah :beer:
Post by ajfoxy » May 10th, 2018, 1:49 am
:noqview:
Now it is time for the obligatory Q-View. :D
Post by JKalchik » May 10th, 2018, 7:44 am
Still looks like a nice paint job. How long did it take to cut the bullets off & reweld?
pr0wlunwoof
Post by pr0wlunwoof » May 10th, 2018, 9:20 am
I just cut the top bullet that was welded to the cook chamber. Took 15-20 minutes to adjust and weld back on.
pr0wlunwoof
Post by pr0wlunwoof » May 10th, 2018, 9:22 am
I also put a few beads of weld on the door frame where the seal wasn't as tight.Image
Post by JKalchik » May 10th, 2018, 10:11 am
That's not bad for time, but if you only adjusted your top hinge, I'd bet your door is a little twisted now. :( OTOH, if you've got a good seal.... go smoke some food. :)
pr0wlunwoof
Post by pr0wlunwoof » May 10th, 2018, 7:50 pm
Got the heatermeter servo and fan working. Ready 4 some test cooking.
pr0wlunwoof
Post by pr0wlunwoof » May 12th, 2018, 11:21 am
It has begunImageImageImage
pr0wlunwoof
Post by pr0wlunwoof » May 12th, 2018, 7:35 pm
Yep its goodImageImageImageImage
Post by Big T » May 12th, 2018, 8:03 pm
