Mini Gravity Feed.
pr0wlunwoof
Mini Gravity Feed.
Post by pr0wlunwoof » December 2nd, 2017, 11:53 am
It has begun. Got my plans. And got some metal. Now I need some time.ImageImage
Sent from my SM-G935V using Tapatalk
Last edited by pr0wlunwoof on December 4th, 2017, 3:34 pm, edited 1 time in total.
Re: Mini Gravity Feed.
Post by ajfoxy » December 2nd, 2017, 5:28 pm
You are on your way now.
A bit of advice from someone who has been there... go through the plans several times. Make sure you understand how it all comes together.
And on thin metal, stitch weld. But most of all... enjoy the journey. :kewl:
Post by Weldun » December 2nd, 2017, 5:49 pm
You mention time, my advice is that when you do find time you don't allow yourself to rush your build. Mistakes are bound to happen when you rush and quality is certain to suffer as a result of the hurry and get it done mode, trust me when I tell you we all know how bad you want to get your build done. Keep in mind these things last a lifetime so you'll either have a lifetime to admire your build or a lifetime to look at it and wish you would have slowed down a bit and paid attention to the details. Good luck, have fun and remember we're all here to help with any issues you may encounter.
Cole
Post by Cole » December 2nd, 2017, 6:35 pm
Is that 5/16" plate going into the Mini?
pr0wlunwoof
Post by pr0wlunwoof » December 3rd, 2017, 11:10 am
Cole wrote:Is that 5/16" plate going into the Mini?
That is the plan. Going to use it in place of the 1/4 sheet. It was a donation to the project and will help save a few dollars. Trying to get my metal order together and hopefully have it placed in the next few days.
I cannot find 1 3/4 size tubing on the plans? It is referenced in the cut sheet and shopping list as FD but on the plans it says 1 1/2" tubing. Was this something that changed on the plans?
Post by Weldun » December 3rd, 2017, 12:50 pm
All the tubing used on my mini was 1 1/2" square.
Heatermeter builder
Post by Heatermeter builder » December 3rd, 2017, 5:30 pm
The 1 3/4 sounds like it was from the double pan plans. I would double check all plans and cutlist very carefully. I found a few mistaks in the double pan gravity feed smoker, that has cost me extra money.
pr0wlunwoof
Post by pr0wlunwoof » December 3rd, 2017, 6:13 pm
Yeah. It has 3 different size square tube and 4 different plate widths. I think I can do it all with 1 tube and 3 plate sizes. The casters are mounted to 2inch tube and 1/8th plate. I can manage that with what I have on hand. Has anyone found a good caster that isn't $25 a pop?
Post by Weldun » December 3rd, 2017, 6:25 pm
I found these after wasting money on a cheap set, I've been really pleased with these.
https://www.menards.com/main/tools-hard ... 37&ipos=11
pr0wlunwoof
Re: RE: Re: Mini Gravity Feed.
Post by pr0wlunwoof » December 3rd, 2017, 6:41 pm
Weldun wrote:I found these after wasting money on a cheap set, I've been really pleased with these.
How much do you think your mini weighs?
Post by Weldun » December 3rd, 2017, 6:46 pm
I really don't know, it's certainly more than two guys are going to load into the back of a pickup truck.
pr0wlunwoof
Post by pr0wlunwoof » December 3rd, 2017, 6:58 pm
Weldun wrote:I really don't know, it's certainly more than two guys are going to load into the back of a pickup truck.
Yeah that sheet I have weighs 326.7072 pounds based on a calculator I found. Half of that plus the 3 sheets of 16 gauge at 245.0304 pounds. I'm guessing around 500 pounds when everything is done.
jtoona
Post by jtoona » December 3rd, 2017, 10:09 pm
The cut list for the mini has 1-3/4" tubing used for the door. The plan sheets say 1-1/2". I couldn't think of why you'd use different sizes. I say go 1-1/2" and make your life easier.
Heatermeter builder
Post by Heatermeter builder » December 4th, 2017, 5:06 am
Casters at harbor frieght are pretty good, I hope. I got casters rated for 600 pounds pretty cheap.
pr0wlunwoof
Post by pr0wlunwoof » December 4th, 2017, 10:07 am
That's what I was thinking.
pr0wlunwoof
Post by pr0wlunwoof » December 4th, 2017, 10:08 am
Heatermeter builder wrote:Casters at harbor frieght are pretty good, I hope. I got casters rated for 600 pounds pretty cheap.
I will have to look at those. Did anyone opt for locking casters?
jtoona
Post by jtoona » December 4th, 2017, 11:50 am
Yeah HF is the place to go for casters. Get locking ones if you want!
Post by Rodcrafter » December 4th, 2017, 3:30 pm
Be careful about putting pages of the plans on your posts please. Just be glad I'm the one telling you this.. lol
pr0wlunwoof
Post by pr0wlunwoof » December 4th, 2017, 3:36 pm
Rodcrafter wrote:Be careful about putting pages of the plans on your posts please. Just be glad I'm the one telling you this.. lol
I figured it was the same as what you can see on the site before purchase :oopssign: . I took it off.
Post by Rodcrafter » December 4th, 2017, 3:43 pm
No problem. That page is about the only one you can use like that.
pr0wlunwoof
Post by pr0wlunwoof » December 7th, 2017, 5:00 pm
Just made my metal order.... Learned an important lesson. Do not talk fast when ordering. The difference in 3 3/16th sheets of metal and 3 sheets of 16 gauge metal is about $250. Metal cost went from $530 to well under $280..... Glad I called back and had them tell me piece by piece the cost of the order.
Post by Weldun » December 7th, 2017, 9:55 pm
pr0wlunwoof wrote:Just made my metal order.... Learned an important lesson. Do not talk fast when ordering. The difference in 3 3/16th sheets of metal and 3 sheets of 16 gauge metal is about $250. Metal cost went from $530 to well under $280..... Glad I called back and had them tell me piece by piece the cost of the order.
You bring up a good point, I always order by email and have them send me an order confirmation which I go over and double check things, this is especially important when ordering material that you're having cut.
pr0wlunwoof
Post by pr0wlunwoof » December 8th, 2017, 1:27 pm
Just bought my insulation. I feel like 48 sft should be more than enough. Might have to find another project to use it on ;) .
pr0wlunwoof
Post by pr0wlunwoof » December 16th, 2017, 4:19 pm
Working on cutting my sheet metal. I noticed on the .dxf file that the F plate is longer than on the cut sheet. Anyone know why?
Post by ajfoxy » December 16th, 2017, 5:43 pm
You might need to give Frank a call to find out.
