I am just curious if there is a reason why most smokers are round. I have access to cheap plate steel.
Is there any reason why smokers are round and not an octagon shape? Will I have problems with an octagon shaped smoker?
Round vs Octogon Shaped Cook Chambers
- Wants to build a smoker
- Pete Mazz
- Administrator
- Title: Meathead
Re: Round vs Octogon Shaped Cook Chambers
Only because old tanks are available for cheap and they save welding. Nothing at all wrong with octagon shape.
- Dirtytires
- Expert
- Title: It ain't broke...yet
- Expert
- Title: Papa Oso
Can find cheap tanks on Facebook Marketplace, and some guys have found success finding cheap tanks at scrap yards.
Might be worth a look. Plate makes for a nice smoker.
They have a nice set of plans on here for a Mack build, which is made from plate.
Has a nice warming chamber too. Lots of guys build them either way. The main thing is follow the engineering that is provided on this site.
Both work like a charm when you get your volumes dialed in
Regards,
First build- Santa Maria Smoker: https://smokerbuilder.com/forums/viewto ... 7a614a230a
- dacolson
- Expert
- Title: Lucky and grateful
My first build was an octagon. Works great.
Dave C - QueNorth Smokers
Farmington, MN
Farmington, MN
- dacolson
- Expert
If you go octagon, one thing I would change is to do 6 sides all the same width but do the front and back sides half again as wide. This will give you a deeper tank and will give you more room for a double rack. Mine has 10” width x 48” length and I have a double rack. It’s pretty tight. I’d do 16” front and back instead and give myself more room.EverydayDiesel wrote: ↑November 21st, 2020, 12:03 amThanks for the replies! I really appreciate the help
Good luck!
Farmington, MN
Farmington, MN
