30”x 53”Reverse flow
GHS11
Post by GHS11 » October 9th, 2019, 9:22 pm
How far below my bottom grate should I put my baffle plate?
Re: 30”x 53”Reverse flow
Post by Dirtytires » October 10th, 2019, 9:36 am
Somewhere in the 5 inch range.
GHS11
Post by GHS11 » October 10th, 2019, 9:46 pm
Dirtytires thank you! I am excited about my build and just hoping everything turns out for the best!
GHS11
Post by GHS11 » October 27th, 2019, 11:42 pm
On my smoke stack will it be ok to 90 out of the back to utilize more of my cook chamber and plus I would like to have a damper going into a warmer down there on the end?!! Thanks for your input
Post by Dirtytires » October 29th, 2019, 2:09 am
A lot of people 90 off the end. I personally recommend mounting it at top/center to avoid stale air being trapped but I’m only one opinion.
A damper between the cook chamber and warming box is a good idea. I also put one between my firebox and warming chamber.
GHS11
Post by GHS11 » October 30th, 2019, 12:56 am
How would I 90 off the end of the warmer is there?
And another question I have is since I will be using a 30” diameter pipe and you suggested my baffle plate be no more than 5 inches below my bottom grate that would leave me roughly 10” below. What would be the ideal size rectangle to cut for my throat . And I’m assuming I have to match that on the other end of the baffle .. correct?
Post by Pete Mazz » October 30th, 2019, 4:11 am
You need to run your numbers thru the PitCalc. Some sort of sketch would help
