Calculations for a vertical
All the calculators you'll need to design your own smoker.
JRINNE
Post by JRINNE » April 15th, 2021, 10:25 am
Wanting to build a verticals offset smoker as I already have the verticals cabinet. Will the sizes from the pit calculator be correct for a vertical? Firebox, intakes, throat etc.
thanks
Jr
Re: Calculations for a vertical
Post by Big T » April 15th, 2021, 5:32 pm
The pit calculator is designed for a horizontal offset so I don't think it'll be the same for a vertical. I don't know of any calculators for a vertical.
Post by Dirtytires » April 16th, 2021, 10:53 am
Ditto.... you are on your own if you build a vertical. Remember that heat transfer is much better as the heat source is directly below the cook chamber and therefore allows the firebox to smaller than that on an offset. To allow you the control you need, many people decide to install a slide damper on the throat to help control the heat input.
JRINNE
Post by JRINNE » April 17th, 2021, 7:44 am
That’s what I figured, thanks for the input.
Return to “SmokerBuilder® Calculators”
