"Q" Train
Want to build a smoker with a Themed Design? Six Shooter, Train, Baseball, or whatever you can think of. This is the place!
Re: "Q" Train
Post by temurf » July 11th, 2016, 8:49 am
Here are a few pics of the WC
Re: "Q" Train
Post by temurf » July 11th, 2016, 8:55 am
I am getting more and more excited about this build now that it is starting to look like something.
Re: "Q" Train
Post by temurf » July 11th, 2016, 9:04 am
We still have a lot more to do but the work we've been putting into this project is starting to show.:bigfoot: Thanks again to everyone for the encouragement and advice. :ymapplause: I couldn't have gotten this far without it.:kewl: Y'all are awesome. :-bd
Re: "Q" Train
Post by Big T » July 11th, 2016, 11:02 pm
It looks like you've been busy, it's starting to look like a smoker now. :kewl:
Re: "Q" Train
Post by Squiggle » July 12th, 2016, 1:17 am
:LG: :beer:
Re: "Q" Train
Post by Rodcrafter » July 12th, 2016, 12:04 pm
I've been looking at you cooker since you posted the pics of the WC. The WC is twice as big as the CC, I'm guessing. I've never seen this done before. I hope this all works out, but the taller the WC the harder it is to get a controlled temp. Considering the FB was based on a really pretty small CC. This could be the exception to the rule of the WC is a free heated source for cooking. Being this tall you may have to damper the opening between the CC and the WC so you can cook in the CC and use the WC as such. But on the flip side if you put racks on all those shelves you will for sure be able to make great jerky and lots of it. I say that because it only has to run 155 or so to do it. If I had known the WC was going to be so tall and wider than the FB I would have suggested something else. I hope this works. I good sketch is always worth the effort.
Re: "Q" Train
Post by temurf » August 7th, 2016, 5:46 pm
I know that its been awhile since I have had time to post any pics but we have been making some steady progress since my last post. We still need to make the cooking grates and design a damper between the FB and the WC, and install a shadow plate above the inlet to the WC from the FB.
My apologies RC. I am not ignoring you. I honestly thought I had addressed your concerns about the WC. I must have forgotten to submit that post.
Anyway, the original intent was to use the WC to keep things warm not to actually cook. That being said, I have installed a damper between the WC and the CC. Here it is in the open position.
And in the closed position.
Re: "Q" Train
Post by Rodcrafter » August 7th, 2016, 5:50 pm
Sweet
Re: "Q" Train
Post by temurf » August 7th, 2016, 6:00 pm
Marking the hole for the stack.
Re: "Q" Train
Post by temurf » August 7th, 2016, 6:13 pm
Installing the stack.
Re: "Q" Train
Post by temurf » August 7th, 2016, 6:24 pm
This baby got too heavy to move around safely so we mounted her on wheels.
Re: "Q" Train
Post by temurf » August 7th, 2016, 6:32 pm
She is far from being complete but we fired her up this morning for a test run. It seemed like a shame to waste a good fire so I threw a couple of racks of Baby Backs on this temporary grate.
Re: "Q" Train
Post by Rodcrafter » August 7th, 2016, 6:33 pm
Nice
Re: "Q" Train
Post by temurf » August 7th, 2016, 7:09 pm
The test fire went really well. :bigfoot: I am really stoked about this smoker (pun intended). :D
I started with about a half a large chimney of coal and a small log of pecan.
I hung a cheapo temp probe where the cooking grate will be and opened the intake all the way. Within 15 minutes we were up to temp in the CC.
I don't have a damper between the FB and the WC yet so I put a chunk of half inch plate over the opening and I closed the damper between the FB and the WC.
An hour and 10 min after starting, I added another log. The temp in the CC hovered between 225 and 235 with little adjustment over a six hour test run.
It looks like she is going to be efficient, each small log lasted more than an hour.
Re: "Q" Train
Post by temurf » August 7th, 2016, 7:29 pm
Before I put the ribs on I decided to experiment with the WC.
I opened up the WC to CC damper all the way. I removed the plate from the FB to WC opening. I closed the CC chimney and opened the WC chimney.
Within 10 minutes the temp in the WC was almost 325 and the CC temp was 230.
I'am really excited about this because even though I did not originally plan on cooking in the WC, it looks like I now have a lot more capacity. When I get the FB to WC damper installed I think I will have precise control over the WC temp.
Re: "Q" Train
Post by temurf » August 7th, 2016, 7:32 pm
:rulz: Before I forget, here is the obligatory Q-view:
Re: "Q" Train
Post by Tom_Heath » August 7th, 2016, 7:40 pm
Looking good brother. Glad the first test went well. I was concerned that you were going to have to run multiple mass air flow sensors, but it sounds like you are good.
Re: "Q" Train
Post by Pete Mazz » August 8th, 2016, 4:22 am
Very nice! You're going to really like having that vertical cooking ability.
Re: "Q" Train
Post by Rodcrafter » August 8th, 2016, 4:39 am
Oh yeah
Re: "Q" Train
Post by Squiggle » August 8th, 2016, 4:41 am
:LG: :beer:
Re: "Q" Train
Post by Big T » August 8th, 2016, 8:41 pm
Re: "Q" Train
Post by temurf » October 30th, 2016, 10:05 pm
I haven't been able to post my progress in awhile, but I have been making progress.
I'll bring y'all up to date.
As it turned out, we had a problem with the door on the horizontal cooking chamber warping due to the thin metal. We couldn't get a good a good seal.
We had some scraps of heavier angle laying arround so we decided to build a frame for a flat door.
Re: "Q" Train
Post by temurf » October 30th, 2016, 10:10 pm
Next we installed the stack on the Vertical cabinet.
Re: "Q" Train
Post by temurf » October 30th, 2016, 10:14 pm
Here she is loaded up on the trailer.
Re: "Q" Train
Post by temurf » October 30th, 2016, 10:22 pm
All done now except for the cosmetics. I wanted to make sure she worked the way I wanted her to before I worried about what she looked like.
I am definately pleased with her performance. (more about that later)
Doesn't she look a lot better with a coat of paint?
Return to “Theme Builds”
