Brisket Trimming 101
Tips, Tricks, Q and A for Cooking Techniques
alleyrat58
BBQ Comp Team Name: TWSS! BBQ
Post by alleyrat58 » March 30th, 2013, 7:35 pm
I used to have a really good link on some states BBQ society page, but I can no longer find it, so here is my attempt to teach the SBs how I trim a brisket.
The first step is to remove a large hunk of fat on the on the meat side of the brisket which I have always heard called the kernel. Underneath the kernel is a strip of fat which separates the point from the flat. As you can see I use a large scimitar throughout this tutorial, however a smaller version of the same knife is helpful for cleaning up, after the kernel is removed.
In the next three pictures you can see the vein of fat which separates the point from the flat. Take note of how the vein lines up so you can remove it easily.
The next step is to cut a notch in the top of the brisket where the vein is. Cut straight down in a triangular fashion to remove the top piece of the vein. Don't cut too deeply.
Now, in the notch you just created, cut another notch into the vein horizontally. This will be your marker to show you where to start cutting after the brisket is cooked. You can do several things from here. You can separate the point and the flat entirely, or you can separate them farther, but not entirely and trim fat to get seasonings down inside of there. This is as far as I go.
This is the grey meat. I don't know why it's grey, but it just seems nasty. Cut that nasty-ness off of there.
Flip the brisket over and about half way down, start scraping off large hunks of fat. I only remove the fat from the point and not from the flat. The reason being, that if you don't it becomes difficult to get seasonings into the point. Also, there is enough marbling in the point to keep that meat moist. Finally it helps the point cook faster than the flat so it all gets done at once.
Keep Trimming
Until it looks like this.
Finally your finished brisket will look like this. Another helpful hint, but I don't personally do it, is to lop off one corner of the brisket in the direction that you will be slicing, that way you already know where to start.
Then I inject across the grains so the liquid will permeate perpendicular to the injection holes, rub, and hold it overnight. The we smoke until it's done. One thing about brisket, there is no magical temp or time, brisket gets done when it feels like getting done. When you probe it with a therm and it feels like warm butter, it's done. Until then, keep cooking it!
TuscaloosaQ
Title: Truly blessed
Re: Brisket Trimming 101
Post by TuscaloosaQ » March 30th, 2013, 7:44 pm
Nice Job alleyrat, I am constantly learning!!!!!!
TuscaloosaQ AKA"white knight of the blue light"
Post by Smokeone » March 30th, 2013, 8:39 pm
Excellent!
Thanks AlleyRat! I will give that a go on my next one. :beer:
Post by Frank_Cox » March 30th, 2013, 8:57 pm
Great "Tutoral"!!!
Thanks for that! :beer: :points: :points:
Grabber70Mach
Post by Grabber70Mach » April 1st, 2013, 7:56 am
Thanks is this going to be made a sticky?
alleyrat58
Post by alleyrat58 » April 1st, 2013, 9:46 am
Grabber70Mach wrote:Thanks is this going to be made a sticky?
Yep.
Post by The Czar » April 1st, 2013, 10:22 am
okay....okyay....that was pretty good for a Cornhusker.... :beer:
Post by Gizmo » April 1st, 2013, 5:38 pm
Corn fed is what makes brisket worth cooking!
SO THERE!
DUAYNE B
Post by DUAYNE B » May 4th, 2013, 1:20 pm
I wish I had read this 12 hours ago, got a btisket, 4 pork butts and 6 racks of ribs on now. Spare, st. Louis and bbayback..... nice post Alleyrat :beer: :beer:
Return to “Food Prep and Cooking Techniques”
