My first UDS build
Swass
My first UDS build
Post by Swass » June 9th, 2014, 12:58 pm
Hey all. My first time here and I thought I would share my uds build
I wanted to get a new smoker since my old one was one of those cheep smokers they sell at Home Depot
I started with a 55 Gal Drum. I drilled 3 holes 1" wide. 2" from the bottom. 1 is for the rear vent and the 2 are spaced equally on both sides for the side air intakes.
It had Motor Grease in it so I had to do a couple burns.
After the burn It looked like this.
I pressured washed the inside and out.
I ground down the outside to bare metal.
I used high temp header primer on the outside of the barrel and lid.
I also primered the hardware. I used 6 90deg elbo's 3/4" , 2 Black 23" pipes, 2 Ball valves , 4 3/4" plugs , 14 conduit washers, 2 u bolts , 6 stainless steel bolts and washers.
ImageI put a coat of black high heat spray paint on the drum
I used yellow high heat header paint on the lid and pipes.
I also used high temp header paint on the drum black
I'm in Pensilvania so I sorta did a black and yellow theme.
I put a 3/4" pipe joint for the rear vent in with 1 washer on the outside and 1 on the inside.
I screwed on the pipe to a 90deg 3/4" elbow along with the ball valve and attached it the sides using a washer on the inside and out side. It is attached using the u bolt on top that way the pipe will not move when you open and close the valve.
I found the center front and drilled 2 holes for my probes.
I used 2 brass fittings and drilled out the center to allow the probes to go though.
I drilled 4 1" holes and attached the 90deg elbows on the lid using the conduit washers on top and bottom. This will be for ventilation.
I'm using 2 replacement grates from a 22 1/2" webber. I used 3 stainless steel bolts and washers for each grate and spaced them apart equaly around. The top bolt is 3 1/2" down. The bottom bolt is 9 1/2" down. I painted the tops of the the bolts yellow.
And here is the final product
I still need to build an basket and season the pit. I'm smoking ribs Monday.
I will be using my new probe set from Maverick.
SmokinFF
Re: My first UDS build
Post by SmokinFF » June 9th, 2014, 7:55 pm
:LG: :beer:
Clover Ridge Smokers
Title: Driven By Passion
Post by Clover Ridge Smokers » June 9th, 2014, 8:22 pm
Looks like it will smoke to me.
Post by The Czar » June 9th, 2014, 8:23 pm
Interesting exhaust set up....let me know how that works for ya!!
Post by Clover Ridge Smokers » June 9th, 2014, 8:25 pm
Seriously DC? you really haven't see that before?
Post by The Czar » June 10th, 2014, 6:01 am
I can't remember seeing it before...
Post by Gizmo » June 10th, 2014, 4:47 pm
You did a fantastic job on that UDS! :kewl:
If it used to hold motor grease would it be a good idea to run a quick batch of cheap chicken parts through there first to make sure it isn't imparting any "less than desirable" flavors to the meat? :D
Post by Smokeone » June 13th, 2014, 8:27 pm
bwild408
Post by bwild408 » July 2nd, 2014, 8:24 pm
Nice UDS. I like the yellow/black paint job. With that said, lets get some meat on and start smoking. :beer:
Post by Rodcrafter » July 6th, 2014, 7:15 am
Very nice
Post by Frank_Cox » July 6th, 2014, 9:28 am
:LG: :LG:
What was the idea behind the bottom vent on the back being left open and a different size?
Swass
My first UDS build
Post by Swass » April 14th, 2015, 10:23 am
Frank_Cox wrote::LG: :LG:
Sorry been gone for a while.
I have the vent the same size as the side ball valve vents 3/4
I open all up to get the temp up then plug it after It reaches the desired temp.
Winter crept up on me so I didn't get a chance to do to many smokes on it. I'm modifying the vents to see if I can control the temps better.
For some reason the temp is either to high or to low. I may have air leaks in the lid.
Swass
Thanks for the compliments. All
