uds build questions
ejaeger
uds build questions
Post by ejaeger » March 6th, 2014, 4:03 pm
I recently got a used food grade barrel, 55 gallon. I got it sand blasted inside and out to remove the paint on the outside and the red liner inside. The first question is should it be burned out still?
Question 2: weber replacement grates are listed as 22.5". Is that the actual diameter of the grate or is that the grill size it fits?
SmokinFF
Re: uds build questions
Post by SmokinFF » March 6th, 2014, 4:26 pm
If they blasted it to bare metal, start building. No need to burn.
2. That's the ones I use. Check out Menards.com. Cheapest place I've found to buy em. Just make sure you order the 22 1/2". I ordered the 21" and it didn't work so good. :oopssign:
Post by The Czar » March 6th, 2014, 6:22 pm
Yeah.....what he said
Clover Ridge Smokers
Title: Driven By Passion
Post by Clover Ridge Smokers » March 6th, 2014, 10:43 pm
the 22.5" at Menards run around $9. Great value.
Rev.Mike
Post by Rev.Mike » March 7th, 2014, 12:45 am
ejaeger
Post by ejaeger » March 7th, 2014, 1:15 pm
Sweet deal. Thanks.
