Insulated cabinet build
AKA- Pellet Poopers
jabbey71
Re: Insulated cabinet build
Post by jabbey71 » January 15th, 2015, 9:39 pm
Thats fine no problem. I understand completely. Thanks. If you were to do the frameless cabinet, would you build it the same size?
Post by Tom_Heath » January 15th, 2015, 10:07 pm
Yes sir, with frame its 1.5 inch wall. so frame less you still make the bends so that you still have a wall thickness that fits the insulation perfect.
smoking247midwest
Post by smoking247midwest » March 17th, 2015, 5:35 pm
Very nice! I have been looking to build the same style..I was wondering..I have a 18 inch auger system.. Any measurements you recommend for going a little bigger?
SOILhunter
Post by SOILhunter » March 30th, 2015, 11:09 pm
Sorry I missed all the comments guys...mine is welded out completely inside and out...anywhere I passed through the wall is also boxed in so nothing can get to the insulation...if you need any dimensions still just let me know!
I had intentions of putting the 18" in this one but Frank was out of stock at the time and I wasn't waiting! I have no issues with the 12" though, I just assumed I needed the burn pot to be centered, I'm sure you can add some size to the cook chamber as long as it's well insulated, I can't recall what the BTU rating is on these drives but they can handle a fairly large chamber...mine has no issues running up to 400.
juan@cwelds.com
Post by juan@cwelds.com » April 8th, 2015, 11:53 am
We are looking to build a new pellet smoker and wondering about how many cubic inches an 18" auger vs a 12" auger will smoke or maybe another way to ask would be how many square inches of racks would be fed off of each size. Thank you for your help and we apologize as we are new to this.
Thank you
Post by Rodcrafter » April 8th, 2015, 2:22 pm
The limited experience I have looks to me like the length of the auger is to place the fire pot in the center of the CC. Not how much it will smoke.
SOILhunter
Post by SOILhunter » April 9th, 2015, 8:55 am
That's right Rod...both offer 36,000 BTUs....I'm not sure how much space that can handle but I know it works really well for mine.
MattTucker
Post by MattTucker » April 25th, 2015, 11:11 am
Looks great. Did you follow any plans or have any plans you can share? Also curious what the fire chamber area looks like (drip tray, heat plate, etc).
Check out my blog:
The Ozark Chronicles
SOILhunter
Post by SOILhunter » April 26th, 2015, 1:25 am
I didn't use any plans on it just kinda figured up what I wanted and went from there. If I was to do it over again I would definitely go with a square tubing (1.5-2") over the rectangle just to make things a bit easier. I'll try to give ya what pics I've got. I think the angle of the drip pan has changed since that pic...I had to bring it up to clear the heat deflector over the burn pot.
Return to “Pellet Smokers”
