Old new pipe
- has a junk pile that will one day smoke LOTS of BBQ
- Title: Member
Old new pipe
I'm new here. Thanks for having me.
I am about to start a new build. It's not my first. The cooking chamber will be made from a piece of steel pipe 40" diameter and 12' long. Half inch thick.
The pipe was new 20 years ago and has never been used. My question is how and when to treat the surface rust inside the cc?
(I plan on sandblasting and painting the outside when finished)
Thanks for the help!
- Dirtytires
- Expert
- Title: It ain't broke...yet
Re: Old new pipe
Welcome to the group....glad to have you.
Obviously, now is the easiest time to sandblast the pipe. You can do the inside and not have sand in your pit forever and maybe hit the outside as well so welding and cutting are easier during the build. Bad part is you will need to get I’d done again before paint, but only the exterior.
If the interior is relatively clean, you could hit it with a flap wheel but I suspect after laying around for 20 years it needs a little more work.
- dacolson
- Expert
- Title: Lucky and grateful
Re: Old new pipe
My vote is with Dirtytires. I can't imaging crawling down the inside of that pipe with a flap disk or wire wheel. My back and knees hurt just thinking about it. If you have the equipment or can get it done for cheap, I'd sandblast it now for sure. Only other thought might be to cut your doors first which might make it easier to access the interior if you don't want to crawl inside.
Good luck!
Dave C - QueNorth Smokers
Farmington, MN
Farmington, MN
- Expert
- Title: Member
Re: Old new pipe
Good god, man. A 12' long, 40" diameter, 1/2" wall thickness pipe? HOW MUCH DOES THIS THING WEIGH?
I'd throw down w/ @dacolson and @DirtyTires..... sandblast it now.
- Title: Member
Re: Old new pipe
It weighs about 2500 lbs, according to the online weight calculator.
Its way bigger than I really need......but what are you gonna do?
Its gonna be a different build than most on here would do. But it should work.
I will listen to the advice given here, and have the inside blasted before proceeding with the build
- Expert
- Title: Member
Re: Old new pipe
As I've got a few minutes, lessee..... pi(d)(l)...... a shade under 126 ft^2, and about 20 lbs/ft^2..... I come up with just about the same number. You're gonna have some serious heat retention in this thing. Just maneuvering it for your build is not gonna be easy. Please don't drop it on your toes.
Go big or go home.
Go big or go home.
- Title: Member
Re: Old new pipe
Lol, I will try to save my toes...all 12 of them
I live in the midst of the East Texas oil field. While it's not what it used to be, there are still many businesses that provide services....
So, I think I will use one of them for cutting the doors and the firebox door
Should we discuss this here or should I start a new thread in the build section
Thanks again
Thanks again
- dacolson
- Expert
- Title: Member
- Title: Member
Re: Old new pipe
I retrieved the pipe today. It's 3/8"... not 1/2". Still, should work fine.
It's awaiting the sandblaster. Will have both inside and outside done. Spray the inside with canola oil and paint the outside.
- dacolson
- Expert
- Dirtytires
- Expert
Re: Old new pipe
3/8 is totally fine. Plenty thick enough to retain heat and much easier to work with than half inch. As a bonus, it also just dropped 250 pounds!!
- Expert
- Title: Member
Re: Old new pipe
<scratches head> 3/8" is 75% of 1/2"..... should have dropped 600 lbs (unless my math is completely off base....) Still, much easier to work with, for sure.
Just for grins, how are you going to cut access doors, and are you planning on using the cutouts for the doors? The cutouts are gonna take some serious counterweights or healthy springs.
- Dirtytires
- Expert
- dacolson
- Expert
- Title: Member
Re: Old new pipe
Plasma cut the doors. Have not decided whether to use the cut outs for the doors. I dislike the face full of smoke that I used to get when I raised the door.... however, that smoker was built a long time ago and had 2 3/8” pipe as exhaust. Seriously undersized
With a bigger exhaust it might not be so bad. Anyway, if I use the cut outs, I’ve thought about hanging the as “barn doors” hinged on the ends, instead of on top.
I’ve also considered a couple of sliding panels as doors.
- Title: Member
- Title: Member
Re: Old new pipe
I will start the new thread on the build section. I invite your comments there. I’m probably gonna get flamed, as my plans are a bit “unusual “
- dacolson
- Expert
Re: Old new pipe
Unusual is welcomed. Looking forward to it.
Farmington, MN
Farmington, MN
- Title: Member
