New Build has started mini GF +6”
BurnBern
Post by BurnBern » July 4th, 2019, 8:12 pm
Hi a little while back I bought the mini GF plans from Frank and started the planning. I went along the route of getting the frame and the firebox CNC cut. I made a change in that i added 6” to the height of the Mini GF.
The cutting was pretty flawless and looked awesome. I’ve welded the frame together already and you will see it in the pics as I’m using it for a workbench to weld on.
Sent from my iPad using Tapatalk Pro
BurnBern
Re: New Build has started mini GF +6”
Post by BurnBern » July 4th, 2019, 8:19 pm
I’ve pretty much almost finished the FB. I’ve just got the chute to weld on and to make a removable fire grate. Here are some photos as to the progress so far.
I wrote front on it as i nearly welded it the wrong way round LOL
BurnBern
Post by BurnBern » July 4th, 2019, 8:20 pm
I cant figure out how to load multiple photos at once so have to do it one at a time
BurnBern
Post by BurnBern » July 4th, 2019, 8:22 pm
Just in case i had a brain fart i wrote on it again. A person can never to sure
BurnBern
Post by BurnBern » July 4th, 2019, 8:24 pm
She’s waiting to be welded on cant wait as that will mean FB almost complete
BurnBern
Post by BurnBern » July 4th, 2019, 8:26 pm
Made the piece to stop the coals from failing into the CC
BurnBern
Another pic of it and I made it so that it’s removable just in case it rusts out a few years down the line
BurnBern
Post by BurnBern » July 4th, 2019, 8:35 pm
Here is the transfer tube and the underside plate. I think that i might have an issue here in that the tube is 10mm short. I presumed that it was cut and bent to the size i gave the shop that cut and bent it. I did not measure it when i collected it but for some reason they cut & bent 2 transfer tubes for me. I might have to cut this one even shorter say 75mm and then the 2nd one cut it 85mm and weld it onto the fist transfer tube.
Post by Big T » July 4th, 2019, 8:48 pm
BurnBern
Post by BurnBern » July 4th, 2019, 9:33 pm
LOL just sent you a PM
Post by Dirtytires » July 4th, 2019, 10:31 pm
Part of the fun is solving the issues that always seem to pop up....
Post by Diggerg » July 5th, 2019, 9:20 am
Post by ajfoxy » July 5th, 2019, 8:56 pm
Is it too short in length or width? If lenght then just weld a 10mm plate on the end facing the opposite wall. If it is width then you might have to do a bit of creative welding to sort it out. Or take it back to your supplier and get them to remake it... don't fancy your chances there though. :D
BurnBern
Post by BurnBern » July 6th, 2019, 12:31 am
Yeah taking it back to supplier there is no chance of that as I had it done about 3 months ago.
It is short in length so as you said I’ll just weld a piece on.
Is the transfer tube welded to the opposite inside wall?
Post by ajfoxy » July 7th, 2019, 4:55 pm
Generally not a bad idea to weld it there for stability. Well I did on my DP.
And at the end of the day if it is a bit short I doubt it will create an issue as all the transfer tube does it transfer the heat along its width so you don't get a hot spot just inside the cook chamber. So if some of the heat comes out the end, not a biggie.
Post by Chromeski » August 16th, 2019, 1:00 am
I would definitely weld it to the other wall. That transfer tube is heavy, give it all the support you can
BurnBern
Post by BurnBern » September 23rd, 2019, 11:25 am
Well the build is off to a start again.
I’m busy cutting the interior plates but had hit a snag. The bottom plate shows that it should be 22” long but the interior width of the back wall plate is 19”.
I’ve cut the interior plate and made the bends as per drawing but when fitting it it is 3” to long.
I’ve triple checked my frame measurements to the drawing and they are correct.
Is this an error on the drawings
BurnBern
Post by BurnBern » September 23rd, 2019, 11:32 am
Post by Diggerg » September 24th, 2019, 7:00 am
I would shift it to the left so it sits on top of the bottom rail.
BurnBern
Post by BurnBern » September 24th, 2019, 8:29 am
Thanks it now fits well.
