55 Gal Reverse Smoker
- Newbie
Morning everyone,
I’ll be attempting my first build this weekend out of two 55 gallon drums but have a few noob questions before I start.
1. My plan is to shorten one barrel to around 20” in length for the FB and have it connected as you usually see the the CC. Would that be appropriately sized?
2. Both barrels have the infamous red liner. My property is in a neighbourhood and a big burn out won’t be a possibility. I was thinking of fabricating and assembling my pit and then getting both the CC and FB to a good temp to burn out the liner. Followed by some grinding and buffing time. Feasible? Or should I just find a way to clean them out in their original state?
All for now!! Thanks in advance
- Dirtytires
- Expert
- Title: It ain't broke...yet
Re: 55 Gal Reverse Smoker
Well, assuming the diameter of the barrel you have is 22.5 inches, that would mean a 20inch section has a volume of 7952sqin. Using the pit calculator, we find that a cook chamber with 55 gal capacity should have a firebox of 4600 sq in. So, if you want to use a piece of barrel, you would use a piece only 11.5 inches long.
In my opinion, that is too short for a firebox and would be pretty unusable as logs won’t fit. I might suggest trying to find a smaller 30 gal barrel of just fabricate a square firebox. The square is so much easier to use and build that it will be worth the effort, in my opinion.
As far as the liner, I don’t know what it is. No problem burning it out later but just putting a hot fire in the firebox won’t work.
- Newbie
I was able to source an old air compressor so I’m going to use that as my FB instead, thicker walls and is slightly larger then the 11.5 x 20 barrel would be! Excited, going to get started tomorrow morning and will hopefully have some pictures to post.
- Dirtytires
- Expert
So, between 5:30 and 11:15am you found a new tank? That’s fast searching.....
- Newbie
Haha the old man is a collector of all things new and old.
Found a new tank for the FB, all the necessary steel for frame and a brand new hobbyist welder still in box all in one afternoon.
- Newbie
What’re you’re thoughts on attaching the exhaust stack to the threaded cap that’s already on closed barrels? Is that hole big enough to properly move the smoke? I’ve seen it done in my research just not sure how efficient it would be. Great idea though.
- towtruck
- Expert
If the calculator calls for that size hole it will work...run it through the calculator and see if it works.The Flying Dutchman wrote: ↑June 28th, 2019, 6:03 pmWhat’re you’re thoughts on attaching the exhaust stack to the threaded cap that’s already on closed barrels? Is that hole big enough to properly move the smoke? I’ve seen it done in my research just not sure how efficient it would be. Great idea though.
- Dirtytires
- Expert
You need to run the pit calculator. Simply welding tanks together and screwing in an exaust pipe without following the numbes increases the chance is a ill-running pit. It really does make a difference!
- ajfoxy
- Expert
- Title: Neophyte Smoker Bldr
