Tow Behind Charcoal Grill
blunt750
Post by blunt750 » April 26th, 2019, 4:42 pm
Has anyone on here ever made one of these. I am looking to build one. Trying to find some plans on how to build. Thanks.
Re: Tow Behind Charcoal Grill
Post by Chromeski » April 27th, 2019, 3:52 am
It's a great idea and easier fo build than a smoker because the numbers are not as critical. Make sure you are not dropping embers all the way home while towing it. Just decide on a size make sure vents and grill are adjustable and chop for it.
If you literally want plans then I'm sure Frank could draw something up for you.
Post by towtruck » April 27th, 2019, 9:11 am
I don't know of any plans but I have used one of those and there are a few things to incorporate to make them work better......things like vents on both sides evenly spaced, a lid that can hinge from the left or the right so you can work from either side, vents in the lid so you can smoke on the grill, a charcoal tray that is adjustable in height without removing the cooking grate, and an ash pan that slides out the back to clean it all out.
Post by Dirtytires » April 28th, 2019, 11:37 am
I was in a bbq store once and they had a cooker similar to that by meadow creek in the showroom. You might look to see if you can find one locally to snap a few pictures and get a few rough measurements. From there, just design what you want.
Nebel
Post by Nebel » May 10th, 2019, 7:17 am
Also, try tracking down someone who has one of those. You can get the exact measurements that way.
