275 gallon oil tank smoker build
Forum questions and assistance
Fuzzy69
Post by Fuzzy69 » April 15th, 2019, 8:41 am
I am currently in the process of building (rebuilding) a smoker for a friend. he had a old smoker set up that rusted out because he used to put the wood fire directly under the grill more like a cooker not smoker!! I have a newer oil tank that I cut open oval side up and im welding a fire box on one end. My question is should I make this a reverse flow smoker or just let it do its thing???? Also there is a rotisserie hooked up on the other end so my friend can cook a small pig. I'm not sure if reverse flow is better for this option, and if so should I use a pipe or a solid plate steel for the flow?? thanks Fuzzy
Re: 275 gallon oil tank smoker build
Post by Chromeski » April 15th, 2019, 10:29 am
Standard offset and reverse flow both work. I would vote reverse flow personally, but that's up to you. If your friend is just going to use it as a grill anyways then save yourself the trouble and don't build a firebox.
Fuzzy69
Post by Fuzzy69 » April 15th, 2019, 5:51 pm
Thanks, he’s definitely going to do more smoking than grilling!! I guess I’ll do reverse flow!
Post by Dirtytires » April 15th, 2019, 7:05 pm
You want a solid plate for the baffle plate. A pipe would eliminate some of the benefits of the reverse flow.
Post by Big T » April 15th, 2019, 10:14 pm
Fuzzy69
Post by Fuzzy69 » April 17th, 2019, 7:41 am
I’m gonna do a solid plate for the baffle, how big shoul the gap be at the end to let up the smoke and heat??
Post by Big T » April 17th, 2019, 6:08 pm
The BP gap is the same size as the throat or up to 25% smaller than the throat. I make them the same size and haven't had any issues.
Post by Dirtytires » April 17th, 2019, 8:12 pm
You found the pit calculator, right?
Plug in your cook chamber and it will give you all the other dimensions.
Fuzzy69
Post by Fuzzy69 » April 18th, 2019, 7:52 am
Thanks I appreciate the help I used the pit calculator and got the information.
Return to “Questions?”
