painting my offset
nitrosmoker
painting my offset
Post by nitrosmoker » July 15th, 2018, 4:17 am
Hello everybody
I painted my smoker with hi temperature paint but at first bbq, the firebox and cook box, they presented on the surface, a white gloss. The paint is with silicone, but I afraid that it could harm about meat and that it not very healthy. I painted only the extrernal surface but not the firebox.
What happened? Is it not safer?
Thank you in advance for any reply
Alberto
I BOUGHT MY NEW BBQ AND THEN MY WIFE ASK, ARE YOU GONNA SELL THE OLD ONE!!! :exp:
Re: painting my offset
Post by Dirtytires » July 15th, 2018, 9:02 am
Hard, if not impossible, to keep paint on a firebox. The temps just burn off the paint.
Some will oil the outer skin after each use instead of paint. It burns into a dark brown after a while and protects it pretty well.
If you painted external only, no harm to the meat.
nitrosmoker
Post by nitrosmoker » July 15th, 2018, 11:07 am
In fact I painted only the external surface on cook chamber and not the firebox. Maybe at the second cooking, the white gloss will vanish. I hope so
Thanks
Post by Big T » July 15th, 2018, 4:38 pm
Did you season the inside of the cook chamber with cooking oil after you built it ?
nitrosmoker
Post by nitrosmoker » July 16th, 2018, 1:13 am
Unfortunately no. I hope that it's not a problem. I used it only one time at the moment. Do you think that his biggest problem?
THS
Post by ajfoxy » July 16th, 2018, 1:50 am
Perhaps before your next cook (just before you light it), use a rag and smear cooking oil all over the inside of your cook chamber. Then cook something a bit fatty and you should end up with a black patina on the metal. This is good and will stop any rust etc.
nitrosmoker
Post by nitrosmoker » July 16th, 2018, 2:22 am
Ok thank you. First of all I'll remove all rust with sanding and before my next cook, I'll smear with cooking oil
:-bd
