Wood burning stove style reverse flow smoker.
inkslinger
Title: Tattoo/Brew/BBQ
Re: Wood burning stove style reverse flow smoker.
Post by inkslinger » August 30th, 2018, 9:59 pm
Getting so close now. Wont be much longer.
Tattooer / Brewer / BBQer
Post by Rodcrafter » August 31st, 2018, 3:19 pm
Sweet
SouthamptonSmoker
Post by SouthamptonSmoker » September 4th, 2018, 1:57 pm
Thanks guys, I am indeed am so close to being about 50% done, I have ordered the gas struts and have trialled their fit with success, the clearance was tight, and I am real pleased with results.
I bought a flue with damper, from a pizza oven, I am keen to close this part of the project, so decided this was sensible thing to buy. I could make everything, latch and hinges etc, but you have to balance it out, or else you will get lost in the detail, and never get done.
Took a video of the gas struts in operation, even a baby can operate. Pleased as punch.
Few pics below
https://youtu.be/ix455jJdMRY
https://youtu.be/7Wj6Za-NPbY
Last edited by SouthamptonSmoker on September 4th, 2018, 1:59 pm, edited 1 time in total.
SouthamptonSmoker
rest of pics...
Post by ajfoxy » September 4th, 2018, 3:41 pm
Very nice. That is looking very flash. :kewl:
Post by Big T » September 4th, 2018, 4:09 pm
The struts make short work of opening the door for sure. :kewl:
richy20
Post by richy20 » September 4th, 2018, 4:44 pm
That is so awesome!!! Great work :kewl:
JRINNE
Post by JRINNE » September 4th, 2018, 9:57 pm
Very nice work, that thing is sweet.
SouthamptonSmoker
Post by SouthamptonSmoker » September 5th, 2018, 1:50 pm
Thanks guys, was real pleased with how they work out.
I got the flue today, and did a trial fit, I can work with this for sure. It needs cutting down to correct length, but wont do that until a lot later, be nice if it drafts good without the extension on, as that looks real neat.
Few pics below.
SouthamptonSmoker
Post by SouthamptonSmoker » September 11th, 2018, 1:28 pm
I really like that short stack too. Not sure if I can keep it that small though, as until I design the bottom half, I am unsure if there will be a y piece into this flue, or another flue. My preference is the y piece, but when I am using the stove and oven, I need to send pallets through this thing, which I don't want the smoke going through the cook chamber.
Progress feels slow, but it is the nature of the beast now, it is slow monotonous task.
Still some kinda before and after pictures below. I am getting there for sure!!
Post by ajfoxy » September 12th, 2018, 1:56 am
Yep, definitely looking good.
SouthamptonSmoker
Post by SouthamptonSmoker » September 16th, 2018, 1:28 pm
Getting close to being done on the burnishing, so I thought I would put it back in the frame to have a feel for how it is going to look.
Strap a heat gun to the frame to see how it would perform. Seemed to get up to temp in about 30 mins of so, and was a 1.6kw heat gun. Was a bit imbalanced heat wise, but the baffle plate is not properly fitted yet, it is a bit warped and I am going to put a gasket on it.
Few pictures below.
Last edited by SouthamptonSmoker on September 16th, 2018, 1:30 pm, edited 1 time in total.
SouthamptonSmoker
Post by SouthamptonSmoker » September 16th, 2018, 1:30 pm
Rest of the pics.
Post by ajfoxy » September 16th, 2018, 5:46 pm
It is defintely starting to take shape now. Great work as usual... :kewl:
SouthamptonSmoker
Post by SouthamptonSmoker » September 17th, 2018, 10:49 am
Thanks Aj
I went back to check the temp in the cook chamber over 2 hours later. The baffle plate was still hot to touch, it had gone from 225 to 140. I am pretty happy with that. If a 1.6kw heat gun can get this going, I feel pretty confident in the design now. Heat loss will be further improved when i actually install the gaskets on the door and baffle plate.
Got some special shafts to make to hold the gas struts, then I will likely move on to the drawing the bottom half, as the rest other than that is purely cosmetic.
There is however a good couple more weekends work of sanding, but this can be done at any time, and I am keen to see things move forward again.
SouthamptonSmoker
Post by SouthamptonSmoker » October 7th, 2018, 12:40 pm
Make a couple little shaft for the struts, now i have moved onto the drawing.
Got a few pictures, but i still quite early on, so might be difficult to interpret.
The bottom half will be insulated with 50mm ceramic blanket. The oven then has an cavity of 50mm to allow heat to travel all around the oven, both the firebox and oven will be able to damp independantly.
I will be able to send just the firebox straight out the flue, and have everything else off. IE bypass both smoker and oven, and i will be able to turn each on independtly.
The flue will have a y piece on the section on the smoker, and the firebox and oven flue will join in, this will come from the rear of the both, it is quite difficult to explain and i have not drawn it yet. i will add a fabrication on the back, like a rectangle section, which will receive the smoke from both the oven box and firebox, if there dampers are open, a flue will come out of this at the end, at the same place the other flue is. The aim here is when you look directly at it from the front, you shouldnt see the second one, as it wil be behind it, and hidden by the riser as well.
Few pictures of progress.
Post by towtruck » October 7th, 2018, 1:01 pm
That is going to be sharp looking. I also like the control you will have on the exhaust.
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » October 7th, 2018, 2:45 pm
This build is breathtaking. Feels like I am watching "how its made." Keep up the awesome work.
Post by Chromeski » October 9th, 2018, 2:32 am
Definitely a next level build here. A true craftsman
SouthamptonSmoker
Post by SouthamptonSmoker » October 14th, 2018, 11:26 am
Thanks guys.
Managed to progress the drawings further this weekend. Will be another few weekends before they are done but it is coming along nicely.
Few pictures below of the drawings.
SouthamptonSmoker
Post by SouthamptonSmoker » October 14th, 2018, 11:27 am
rest of the pics
Post by towtruck » October 14th, 2018, 12:02 pm
Very nice.......what is the brown colored damper going to control?
