Mack™
jabostick
Re: Mack™
Post by jabostick » June 28th, 2019, 10:41 am
Hey Frank, curious if there is a rough ballpark as to what you should expect the Mack to cost? I assume there are a ton of variables that make it tough to predict but thought I'd ask anyway...
Also, I see a few others mention a 'mini' version of the Mack. Is that still in the works?
forty_creek
Title: 40 Ways 2 Kansas
Re: Mack™
Post by forty_creek » June 28th, 2019, 9:52 pm
MACK needs to stay MACK! I am jealous that OB1 and O812 have MACK! MACK is his own LEGEND! Believe the HYPE!
DRANKIN, SMOKIN and DREAMIN
Re: Mack™
Post by Frank_Cox » July 1st, 2019, 6:37 pm
hey buddy! sorry for the late reply!!!
I always recommend retail price between $4000 and $6700 if on a trailer. depending on the builders cost. if you build it yourself you can easily expect new steel cost to be $1000 to $1600 depending on your purchasing abilities for new steel.
hahaha you're making me laugh brother! Mack could be considered a BBQ assault weapon for sure but yours would be a BBQ Weapon of mass feasting!
jabostick
Re: Mack™
Post by jabostick » July 1st, 2019, 9:02 pm
Thank you sir!
DeltaCabBuilder
Re: Mack™
Post by DeltaCabBuilder » November 5th, 2019, 4:10 pm
Wanting to build one, have a friend with a CNC plasma who will sell me the metal and cut it, (my 4x8 wood cutting CNC sadly won't cut it) and a welding shop next door. Hoping I can weld a bit also on it, maybe on the bottom where it won't show.
My question today is: has anyone build the Mack as a patio? I am on the fence between the trailer or patio style. My 30x36 home shop has a 36x20 carport in front, so the patio would work fine as it would stay on concrete. Use golf cart tires so I can roll or winch up on a trailer? Any thoghts?
Re: Mack™
Post by Dirtytires » November 6th, 2019, 5:43 pm
I see no reason you couldn’t put it on a cart. Make sure you can steer it as it will be too heavy to lift one end to pull around corners.
Hg1027
Re: Mack[emoji769]
Post by Hg1027 » November 6th, 2019, 9:40 pm
I'm doing a couple big pipe fitting smokers. One will live on concrete, driveway to patio to pool side to covered side patio is all level. That one is on 10 inch steel casters, 2 swivel.
The other will need to go across a lawn to storage. We haven't completely figured it out, but currently thinking a single trailer axle very near center of gravity, and small car sized tires. With one axle, it should work for one person to lift one end and spin it around. A leg at each end would keep it from toppling.
Edit: these are about 1000lb, 600 for the tee, 250 for the firebox pipe, ~150 for the frame and casters.
DeltaCabBuilder
Re: Mack™
Post by DeltaCabBuilder » November 7th, 2019, 1:58 pm
Thanks, guys. I thought it should work, wanted to make sure. I have a 5x10 mower/4 wheeler trailer that tilts. Thinking I can mount a boat winch or even a 12volt model on the front of trailer to pull it on if I need to transport.
Brucedg
Re: Mack™
Post by Brucedg » February 26th, 2020, 7:51 pm
Agree more :chef:
Bruce
Mike0585
Re: Mack™
Post by Mike0585 » June 10th, 2020, 12:16 am
Are the plans for the "Mini Mack" still in the works?
