Remodel reverse flow smoker
- beginner
I have a reverse flow smoker that is 24" x 85". I would like to make some changes to the set up. I have a new firebox which is 18"x24"x30" that I want to install. I have questions about the throat size and the height of the baffle plate. How big should the opening from the firebox to the cook chamber be? And how high from the bottom of the cook chamber should the baffle be? How high above the baffle should the firebox be mounted? I have a few ideas. I'm just second guessing myself and would like advice .
- ajfoxy
- Title: Neophyte Smoker Bldr
Re: Remodel reverse flow smoker
One of the more knowledgeable members will pipe up shortly.
Welcome! Your throat should be 104 sq inches, the shape doesn't affect the performance. Pete has a throat calculator that'll help you figure out which shape you want to go with. Most guys run the BP the same height as the top of the firebox but I like to raise the BP an inch higher and add a shadow plate below the BP for the first 12'' or so.
- beginner
Thanks Big T I'll check the calculator
- beginner
It's been awhile, got the mods done, and smoking like a champ.
- ajfoxy
Nice indeed... she looks a beaut.
It is nice when the plan comes together. So did you do what Pete said or come up with something else?
- beginner
I followed the advice I received on this stream and referred to the calculator.Rodcrafter wrote:It is nice when the plan comes together. So did you do what Pete said or come up with something else?
Awesome!
- temurf
- Title: Train Driver
- BBQ Comp Team Name: Rednecks con Fuego
Sweet looking pit.
Looks like its time for some Q-View.
- beginner
temurf wrote:![]()
Sweet looking pit.![]()
- beginner
- ajfoxy
Was it as good as it looked?
I was only asking as I waited for samples.
- temurf
- beginner
The only taste I got was when I was slicing it. So I guess the answer is yes.Rodcrafter wrote:Was it as good as it looked?
- temurf
You have to taste it frequently while slicing any Q.
I'm sure its in the
I'm sure its in the
- ajfoxy
I know what you mean NT I take a brisket to an annual get together each time and slice it and by the time I get my plate I'm lucky if ther is still any there.
- Squiggle
- Title: Reformed non-smoker!
- beginner
It’s been awhile and I took on a new venture. I decided to give a offset with tuning plates a try it’s actually my old reverse flow that got a face lift and put on a smaller trailer.
