• Advertisement
Photobucket
Insulated Charcoal Feeder
Postby Smoker Tom » March 4th, 2012, 11:07 pm
Well guys, I had to make up my mind if I wanted to catch up on the board or start my build.
Welp.....I started my build.
Its been since last August since I worked on my smokers. :? I know I know bad me.
Anyways here it is, 32 inchs wide x 48 inchs tall and 24 inchs deep.
The inside is 409 stainless for the most part, only because I had it and it was cheep.
The top and bottom needed one inch added to each side to make the full 32 inchs wide. I wasnt about to loose those two inchs.
The stand took twice as long to build as the smoke box did. I had to have a way to move it though.
The last few pics show two bends, thats where the door will set into and seal against a gasket.
Since I have NO brake I had to cut a relief and then bend it. After I finished both bends then I welded it to get the strength back. Gettin er bent was a chore but now its done.
Insulation wont be here till the end of the week so probably wont be alot happen this week. Plus I need to figure where I want temp probe holes and such.
All said and done, its gonna have 3 inchs of insulation.
Go Big or Go Home.....Thats what I say.
One of these days I want to learn to weld real good
Image.........Sometimes I feel like a nut.Image.............
Smoker Tom
Title: Moderator
BBQ Comp Team Name: Pit Doctors BBQ
Re: Insulated Pellet Build
Postby Rick » March 4th, 2012, 11:42 pm
Reminds me of an FE100 - winningest smoker in history...
Glad you got 'er in gear Tom - nice job on that structure.
3" insulation? - you know something about our upcoming winters that I don't? after all, I'm only half a state north of you...
What kind of drive unit you gonna use?
Ain't I just full of questions?
:D
Smokerbuilders do it slow to make it last ... ~O)
Rick
BBQ Comp Team Name: Edna's Kids
Postby maccas66 » March 5th, 2012, 12:01 am
Hey thats smoking Tom!, nice welding as well!............can you do mine next time! :D
" I`m so hungry, I`m farting fresh air!"
maccas66
Title: Aussourian Plumber
Postby Smoker Tom » March 5th, 2012, 12:06 am
Yup, the only thing is that mine is almost twice the realestate as the 100.
The plan is to use the standard trager style drive, that I still need to find. I picked up the controller yesterday for 100 bucks. Then when I got home I found the same control for like 115.00 and it came with the temp probe. So since I have the control and I'm not driving back out there I will just order the probe online for 30 bucks.
Then when Franks gets here saterday I will have everything I need execpt for the two fans. One for the auger duct and one as a convection fan in the cook chamber.
After seeing just how big it is in person, I am worried that I will need two augers. We shall see.
And as for the 3 inchs insulation, I am trying something new. They are calling it stone wool and its got a fire rating of 2150 degrees.
Smoker Tom
Title: Moderator
Postby Smoker Tom » March 5th, 2012, 12:11 am
Hey there mac, I know its been awhile since I have made it in here.
Time is tough to come by these days, and OMG I can sure tell that I am working an office job now.
I hurt already, and its not even the day after. I will be in pain tomorrow for sure.
Hey, my welding aint all that, LOL I put on a good show. There is a few you cant see, I was out front and it was windy today so my shielding gas was blown away a couple times. And then I ran out of c/25 and had to switch back to co2.
Smoker Tom
Title: Moderator
Postby maccas66 » March 5th, 2012, 12:37 am
:oopssign: sorry Tom!, what I meant was Hey that is smoking,,,tom!, nice job!! a little play on words that read better down here upside down :homer:
maccas66
Postby dcman (The Czar) » March 5th, 2012, 8:10 am
Tom....I have been hearing about this "build" from Frank for a while now....I am glad to see you finally getting it done....but I can't help to wonder if your gonna make it to competition this year.... :huh:
I wear big women's under all the time......so much room for me and Alleyrat.....
dcman (The Czar)
Postby Smokeone » March 5th, 2012, 10:19 am
Looking good Tom! I say put to auger setups on it anyway, just think of the power you will have. :D
I have a feeling after saturday you will be able to return the controller, cause your gonna need a credit card machine to run this bad boy, if you and Frank get together! :P Throw DC in the mix and you will need two CC machines! :oopssign:
BBQ is just smoke and beers!
Usually more beers than smoke.
BBQ Comp Team Name: Smokerbuilder.com - Competition BBQ Team
Postby Rick » March 5th, 2012, 7:52 pm
You've prolly seen that Traeger unit they call a commercial one with a roll-up door on it (roughly $8,000). I'm guessing it's dimensions from memory at about 30" deep - 48" high and about that wide maybe a little more. It has 3 firepots running off one controller... for what it's worth... :)
...unless you're making your own drive unit - then all bets are off... :-B
Rick
Postby Smoker Tom » March 5th, 2012, 10:50 pm
Its all good mac, I just tilted my head sideways and it all makes sence now ,,, LOL
OMG a credit card machine, just what I need.
I plan on attending the comp at P Hill on the 30th. Just not with my rig. LOL See I know this one guy thats cooking there.....
A pellet rig with a roll up door!!!!! WOW never seen that one. Yet.
And it I could run two auger drives off one controller, that would be awesome.
See, when it comes to the electronics, I am at a total loss. I hope I can beg a little help when it gets down to that point.
In my sleep last night I was tossing around the idea of using the stand as a backup heat source.
Just in case something on the pellet set up fails, I would like to still be able to function. Kinda like a dual fuel rig.
Maybe make a removable plate in the floor of the cook chamber and then build a pull out drawer that could have a coal tray like a backwoods.
This could be built at any time down the road, just thinking, since Frank ask about making it a dual. Pellet Pooper/Gravity Chute.
Could be interesting.
Smoker Tom
Title: Moderator
Next
  • Advertisement
Get our toolbar!
Return to Smoker Clones
Who is online
Users browsing this forum: No registered users and 0 guests
Photobucket
cron
