150 gallon build, lots of questions
Tipps
Re: 150 gallon build, lots of questions
Post by Tipps » July 9th, 2018, 5:08 pm
mock up, still not completely standing on its own, and it will be about 8-1/2" taller when wheels go on.
Tipps
Post by Tipps » July 9th, 2018, 5:10 pm
front spindles in progress
Post by ajfoxy » July 9th, 2018, 5:44 pm
Coming along nicely... :kewl:
Post by Big T » July 9th, 2018, 7:09 pm
Newsmoke
Post by Newsmoke » July 9th, 2018, 9:57 pm
Awesome work! I can't wait to see some of your cooks! Follow up question regarding the smoke stack at center level of the CC.
For the length of the stack should we only measure the vertical height of the stack or vertical height plus radius of CC (if stack at center level)?
Tipps
Post by Tipps » July 10th, 2018, 10:19 am
From what i understand, only the stack portion that is above the cook chamber gets measured.
Post by Rodcrafter » July 10th, 2018, 10:21 am
That’s right
Tipps
Post by Tipps » July 30th, 2018, 1:18 pm
Some progress -
front end is pretty much done, and the pit stands on its own now. Got the door cut out and hinges done. Gotta work on flanges/gasket, and getting the stack on so I can move on to grates, tuning plates, and firebox door.
Tipps
Post by Tipps » July 30th, 2018, 1:19 pm
have to add the bracket for removable steering handle.
Tipps
Post by Tipps » July 30th, 2018, 1:20 pm
Tipps
Tipps
Post by Tipps » July 30th, 2018, 1:23 pm
I didn't really want to deal with a sprung door, so I crawled in the cook chamber before I attached firebox and welded 3 gussets inside. I used a grinder to cut out small notches where my door would be to help me line the gussets up in the correct spot. this worked, the door did not spring. all the welding of patches where the valves and connections were on the tank cause part of the cook chamber to squeeze in some, but I hope I can push it out with a jack and weld a grate support in that place.
Post by Dirtytires » July 30th, 2018, 2:44 pm
Metal is funny. Hope the supports worked but don’t be surprised if it moves some when you remove them to put in your shelves. It can be easily fixed however so dont panic if it does. Project is looking really great and coming together nicely.
Tipps
Post by Tipps » July 30th, 2018, 5:57 pm
I was thinking it still might move, so I may leave the supports on it forever
Post by ajfoxy » July 30th, 2018, 7:47 pm
Looking good. I like the wheels. Adds a nice touch.
Post by Dirtytires » July 30th, 2018, 10:43 pm
They will cut into rack space....I’d cut them out and take the risk.
Post by Chromeski » July 31st, 2018, 1:17 am
Looking very good, the wheels look better than store bought casters would hopefully they roll good
WHeydet
Post by WHeydet » July 31st, 2018, 7:57 am
Hey man that looks killer!
Tipps
Post by Tipps » July 31st, 2018, 11:20 am
Thanks for all the encouragement and help. Maybe I’ll get it finished here in a few weeks, in time for fall and football.
Last major decision - 5” or 6” stack, and up top or out the middle (grate). I cannot decide
Post by Dirtytires » July 31st, 2018, 5:55 pm
What is your stack volume? The larger the inside diameter, the shorter the stack needs to be. It is advisable to get the stack up above your head so you don’t have smoke rolling in your face. My guess is that 6 inch dia will make it pretty short.
Post by Big T » July 31st, 2018, 7:45 pm
Tipps
Post by Tipps » August 10th, 2018, 2:07 pm
a little more progress. Got my stack on, went with the 6" but cut it down some. Got my door flanges on, both stops, a spinning stainless handle that took forever to get just right. I must've tacked and cut and tacked at least 6 times. Also got my lower grate slides in, and deflector near the firebox. Have one cooking grate framed, need to do the others and add the top slides, then on to the firebox door! Starting to see the light here....
Tipps
Post by Tipps » August 10th, 2018, 2:08 pm
I think I may just weld the entire flange to the door
Tipps
Post by Tipps » August 10th, 2018, 2:09 pm
had some company
Tipps
Post by Tipps » August 10th, 2018, 2:12 pm
