• Advertisement
Photobucket
Cast iron help.
Stuff that was cooked on a disco or Cast Iron
Re: Cast iron help.
Postby Smoker Tom » May 27th, 2012, 4:39 pm
The bad part is.......thats a chevy there sittin on....
If it was a ford, it wouldnt even be to the overloads yet.
Go Big or Go Home.....Thats what I say.
One of these days I want to learn to weld real good
Image.........Sometimes I feel like a nut.Image.............
Smoker Tom
Title: Moderator
BBQ Comp Team Name: Pit Doctors BBQ
Re: Cast iron help.
Postby Rick » May 27th, 2012, 9:08 pm
Tom you must be a Ford man ... and I was just starting to like you ... :-w
aif
Smokerbuilders do it slow to make it last ... ~O)
Rick
BBQ Comp Team Name: Edna's Kids
Re: Cast iron help.
Postby Smokeone » May 27th, 2012, 9:11 pm
Careful Rick, there might be a bunch of us Ford guys on here! b-(
BBQ is just smoke and beers!
Usually more beers than smoke.
BBQ Comp Team Name: Smokerbuilder.com - Competition BBQ Team
Re: Cast iron help.
Postby Rick » May 27th, 2012, 9:41 pm
Yeah you're right S1 ... too close to home ....
But I've owned them all and the only one worth anything is the one that gets me home at night with the load intact...
Rick
Re: Cast iron help.
Postby Smokeone » May 27th, 2012, 9:46 pm
Very true!
I guess I'll have to let you slide this time! :beer:
Re: Cast iron help.
Postby dcman (The Czar) » May 28th, 2012, 11:44 am
Wow this thread went so wrong so fast..... =))
I wear big women's under all the time......so much room for me and Alleyrat.....
dcman (The Czar)
Re: Cast iron help.
Postby Tommy Joe » May 29th, 2012, 12:43 pm
Now if that ain't the truth :BDHorse: :BS:
Tommy Joe
FA Builder
FA Builder
Re: Cast iron help.
Postby Tommy Joe » June 6th, 2012, 11:06 am
I've never tryed it yet but I read that if you have a self cleaning oven put the dutch oven it there and set it on self cleaning. If I remember right it's set bottom side up.
Tommy Joe
FA Builder
FA Builder
Re: Cast iron help.
Postby SoloQue » June 6th, 2012, 1:13 pm
You can also get you a plastic trash bag. Coat the pan generously with Easy Off oven cleaner and place in the trash bag. Seal it tight and let it sit over night. Carry that rascal outside and hose it off (might sound obvious but you do not want to splash yourself during the process). You should be down to the bare metal at that point. Then follow steps listed above for reseasoning. I usually give them a quick wipe down with oil and place in the oven as it is still cooling down before I store the pans away. As long as you have removed the moisture from rinsing it out and given it an oil barrier before storing it should not rust back on you. I pick up old pans from time to time at flea markets and yard sales. Whenever I stumble across a keeper in bad shape I use the bag method. You can also place in a self cleaning oven but heck I just dont like the extra clean up of the oven when all the crud falls off.
If it can't be smoked .... try frying it. It that don't work, it's probably best just left alone
SoloQue
BBQ Comp Team Name: Irv's Smokehouse
Previous
  • Advertisement
Get our toolbar!
Return to Disco and Cast Iron cooks
Who is online
Users browsing this forum: No registered users and 1 guest
Photobucket
