1st build from compressor tank questions
Re: 1st build from compressor tank questions
Post by Big T » January 22nd, 2017, 8:51 pm
Tjam9
Post by Tjam9 » January 25th, 2017, 11:29 pm
Getting closer. Don't have a ton of time to work on it this week. A few more pics.
Better view of air intake
Burning for the first time to help clean out the inside of the tanks.
Wheels attached, legs made and flanges for the fb done.
Post by Big T » January 25th, 2017, 11:48 pm
You may want to pull the rubber ends off of those latches unless they're made for high temperature. It looks great!!
Post by ajfoxy » January 26th, 2017, 2:06 am
Looks like there should be a flux capacitor in there somewhere...
Nice build though...
Post by Squiggle » January 26th, 2017, 3:21 am
Big T wrote:You may want to pull the rubber ends off of those latches unless they're made for high temperature. It looks great!!
I was thinking the same thing, I've seen them replaced with normal bolts. Looks fantastic & definitely needs a flux capacitor! :kewl: :beer:
Post by Rodcrafter » January 26th, 2017, 7:27 am
I replace them with carriage bolts. Looks great!
Tjam9
Post by Tjam9 » January 26th, 2017, 10:13 am
Thanks guys. Yeah I already melted some of the rubber. Definitely going to pull off or put carriage bolts. If anyone has a flux capacitor I'll mount it. Haha
Post by Frank_Cox » January 26th, 2017, 7:40 pm
Awesome build!!
Post by temurf » January 27th, 2017, 9:32 pm
:beer: :LG: :beer:
I like it even if it doesn't have a flux capacitor. Staying tuned for the Q-veiw.
Tjam9
Post by Tjam9 » February 2nd, 2017, 12:00 am
Baffle and drain installed. Need to do a little more welding on the baffle and need to finish grinding the drain even to the top of the baffle, but ran out of time today.
Post by ajfoxy » February 2nd, 2017, 2:06 am
Looking good. Almost time for Q-view
Post by mp4 » February 2nd, 2017, 6:30 am
That is truly a work of art...
Post by temurf » February 2nd, 2017, 6:42 pm
:yth: :kewl:
Post by Big T » February 2nd, 2017, 8:13 pm
Did you cut the drain pipe flush with the BP ?
Tjam9
Post by Tjam9 » February 2nd, 2017, 9:24 pm
Thanks guys.
Tjam9
Post by Tjam9 » February 2nd, 2017, 9:25 pm
Big T wrote:Did you cut the drain pipe flush with the BP ?
I cut it flush and still need to grind the weld around the pipe so it's completely flat. Forgot to take a picture.
Post by Big T » February 2nd, 2017, 10:25 pm
:beer: It's really coming together!
Tjam9
Post by Tjam9 » February 2nd, 2017, 11:32 pm
So I just realized that I put my drain on the same side that I'm putting my handle (opposite side of the wheels and same side as my legs). Do you think that this is going to matter? I'm not sure how much grease I will need to drain or how often. Just seems like it would be easier to lift the smoker from the handle I mount to move the smoker around. If this makes a difference I may just drill a few holes on the opposite side and move the wheels.
Post by mp4 » February 3rd, 2017, 6:38 am
I don't think it will matter. Truthfully, I didn't install a drain at all in mine. I scrape off the baffle plate every now and then before I cook (which is never often enough) and I've never had any trouble.
Post by Rodcrafter » February 3rd, 2017, 7:14 am
I put my drain on the same end and I made the legs adjustable so I could make sure it was level wherever I set it.
Tjam9
Post by Tjam9 » February 3rd, 2017, 12:15 pm
Ok thanks. Good to know. Wasn't sure but figured a lot of grease would just burn off during the cook.
I definitely thought about adjustable legs.
Post by Squiggle » February 3rd, 2017, 4:02 pm
Looks amazing dude, fantastic work! :kewl:
SAFETYHARBORREDNECK
Title: ChefBoyareyoukidding
Post by SAFETYHARBORREDNECK » February 3rd, 2017, 9:27 pm
Here's what I did for my exhaust stack.Something to consider for your next build.
I made my door cut at 1" past top dead center and put my stack out at an angle.
The stack also doubles as a door stop/rest!
Here's a pic.
NEVER trust a skinny cook!
Tjam9
Post by Tjam9 » February 3rd, 2017, 10:27 pm
Thanks for the info. Looks good I like your damper design.
Tjam9
Post by Tjam9 » February 4th, 2017, 4:07 pm
Ok got the baffle welded in (a lot of welding) and the drain is now level.
Just need to make the cooking grate, charcoal basket, shelf, chimney damper and handles then paint and BBQ :biggrillin: :)
Return to “Questions?”
