Yep I'm with you, essentially use the scrap as a guide for the holesaw. The holesaw will be a while for delivery so will go onto other bits!dacolson wrote: ↑February 6th, 2021, 9:20 amYour step bit is trashed at the width you are at. Dull. It’s done.BigPete wrote: ↑February 6th, 2021, 5:28 amHaha yes it does look cool.
Check this out, I'm still struggling to get this hole widened from 16/18mm to 20mm. A brand new bit, slowly with oil did absolutely nothing. Really at a loss how to get this drilled I guess as it's hardened now.
Here's also the handle, end drilled, tapped and finished with a countersunk washer.
Here’s a tip to drill that hole you’ve already started once you get your hole saw. It will be hard to finish your existing hole since it’s larger than your pilot hole for the saw. Cut a hole with your hole saw in a piece of scrap. Then clamp or tack the scrap over the hole you’re trying to finish as a guide. It will make finishing that hole so much easier. Use your cutting oil a lot with the hole saw as well. Don’t put too much pressure on it while you cut.
Brick Offset & Vertical Smoker with Outdoor Kitchen
- Needs more Steel
Re: Brick Offset & Vertical Smoker with Outdoor Kitchen
- dacolson
- Expert
- Title: Lucky and grateful
Yep I'm with you, essentially use the scrap as a guide for the holesaw. The holesaw will be a while for delivery so will go onto other bits!BigPete wrote: ↑February 6th, 2021, 10:10 amYour step bit is trashed at the width you are at. Dull. It’s done.
[/quote]
What, no Amazon same day delivery across the pond?
Dave C - QueNorth Smokers
Farmington, MN
Farmington, MN
- Dirtytires
- Expert
- Title: It ain't broke...yet
I have found several key things over the years to help in drilling steel. First is a sharp, quality brand bit....this is not the time to save pennies. Once it gets dull, replace it. Second is lubricant. I use WD-40...little goes a long way. Third is to watch your bit temperature. The oil will help to cool it but allow time for it to cool off between multiple holes or cooling with compressed air will help to maintain its edge longer. Last, but most important, is to allow the bit to cut. Apply a moderate/heavy amount of pressure to your drill and maintain the lowest spin speed you can. Running it fast with light pressure just makes friction that heats it up your bit and destroys it. Because of this, you need a big, heavy duty electric drill as most clutches on battery drills will slip.
- Needs more Steel
What, no Amazon same day delivery across the pond?dacolson wrote: ↑February 6th, 2021, 10:24 amYep I'm with you, essentially use the scrap as a guide for the holesaw. The holesaw will be a while for delivery so will go onto other bits!BigPete wrote: ↑February 6th, 2021, 10:10 amYour step bit is trashed at the width you are at. Dull. It’s done.
[/quote]
There is next-day but I'm too tight to pay way over the odds for a holesaw
I've got a good mains powered Makita SDS that has a lot torque at the expense of high speeds which should be ideal. Over in the US do you find the branded products are a better quality? (In my experience the bits and consumables here are all very similar with a different logo/brand and price)Dirtytires wrote: ↑February 6th, 2021, 11:33 amI have found several key things over the years to help in drilling steel. First is a sharp, quality brand bit....this is not the time to save pennies. Once it gets dull, replace it. Second is lubricant. I use WD-40...little goes a long way. Third is to watch your bit temperature. The oil will help to cool it but allow time for it to cool off between multiple holes or cooling with compressed air will help to maintain its edge longer. Last, but most important, is to allow the bit to cut. Apply a moderate/heavy amount of pressure to your drill and maintain the lowest spin speed you can. Running it fast with light pressure just makes friction that heats it up your bit and destroys it. Because of this, you need a big, heavy duty electric drill as most clutches on battery drills will slip.
- Needs more Steel
Managed to get my ember maker built today the thing is HEAVY!. Had hit and miss welds (porosity) not sure why as I didn't change the settings. Need to so some research why.
- dacolson
- Expert
Did you prep your steel - grind off the mill scale? Also, are you welding outside in the wind? Gas coverage can suffer if it’s windy.BigPete wrote:Managed to get my ember maker built today the thing is HEAVY!. Had hit and miss welds (porosity) not sure why as I didn't change the settings. Need to so some research why.
Farmington, MN
Farmington, MN
- Dirtytires
- Expert
Yes...the brand name abrasive/cutters are much better overall than the off-branded items. Seems the cheep stuff is built to be one-use so really isn’t worth buying as it has such a short lifespan.
- Big Time SmokerBuilder
- Title: Junk Fettler
- BBQ Comp Team Name: Team "Too drunk to care"
What's that stock, Pete - 3/4" bar? Probably needed to be much higher current than you used for the door frame, with an increase in wire feed speed to match.
- mp4
- Expert
- Title: Independent Thinker
- BBQ Comp Team Name: Just a few backyard for fun competitions.
I've had issues similar and lately have noticed that changing the contact tip can make a big difference. I would never change them until the wire fuzed to the tip. Give that a shot...BigPete wrote:Had hit and miss welds (porosity) not sure why as I didn't change the settings.
Sent from my SM-G781U1 using Tapatalk
- Needs more Steel
Na didn't grind off the mill scale as some of the welds took so figured I could get away with it. But yes I was outside and there was a few gusts come to think of it! I know sheffsmoker mentioned about wind before but I didn't think it would be so sensitive.dacolson wrote: ↑February 7th, 2021, 11:50 amDid you prep your steel - grind off the mill scale? Also, are you welding outside in the wind? Gas coverage can suffer if it’s windy.BigPete wrote:Managed to get my ember maker built today the thing is HEAVY!. Had hit and miss welds (porosity) not sure why as I didn't change the settings. Need to so some research why.
Let's see how this next few go and you'll maybe convince meDirtytires wrote: ↑February 7th, 2021, 11:58 amYes...the brand name abrasive/cutters are much better overall than the off-branded items. Seems the cheep stuff is built to be one-use so really isn’t worth buying as it has such a short lifespan.
That was mostly 20mm bar (some 16mm and 6mm plate), was running it around 150-160ASheffSmoker wrote: ↑February 7th, 2021, 12:03 pmWhat's that stock, Pete - 3/4" bar? Probably needed to be much higher current than you used for the door frame, with an increase in wire feed speed to match.
I'll have a check, I hadn't noticed anything when I started but it could well have gotten worse throughout the day! Thanks for the suggestionmp4 wrote: ↑February 7th, 2021, 12:47 pmI've had issues similar and lately have noticed that changing the contact tip can make a big difference. I would never change them until the wire fuzed to the tip. Give that a shot...BigPete wrote:Had hit and miss welds (porosity) not sure why as I didn't change the settings.
- Needs more Steel
So it turns out the missus found some cone bits in Lidl (not sure if you have them in the US but it's a German discount store) so picked me up a pack. 3 HSS cones for £3.50. I thought what the hell, slow speed lots of pressure and lots of oil and low and behold it went through. It's sad but I've never been so happier with drilling a hole
- Cole Leffert
- Title: Country boy!
Awesome! Glad it worked out!BigPete wrote: ↑February 15th, 2021, 1:17 pmSo it turns out the missus found some cone bits in Lidl (not sure if you have them in the US but it's a German discount store) so picked me up a pack. 3 HSS cones for £3.50. I thought what the hell, slow speed lots of pressure and lots of oil and low and behold it went through. It's sad but I've never been so happier with drilling a hole![]()
I have the same ones! I've found the pilot step is done after half a dozen holes, so now use a separate 3mm bit to get them started.BigPete wrote: ↑February 15th, 2021, 1:17 pmSo it turns out the missus found some cone bits in Lidl (not sure if you have them in the US but it's a German discount store) so picked me up a pack. 3 HSS cones for £3.50. I thought what the hell, slow speed lots of pressure and lots of oil and low and behold it went through. It's sad but I've never been so happier with drilling a hole![]()
- Dirtytires
- Expert
- Needs more Steel
So got a fire lit with doors on etc, strangely the top thermometer read 50degC and the bottom 30degC neither of which made sense as the fire was ripping. I put my probe into the middle of the cook chamber and it read better, the graph is over 1hr and I didn't add any new fuel, the spike at 125degC was me opening the FB door a little more. I suspect I may need some sort of baffle over the cook chamber entrance to diffuse the heat so it doesn't race straight up and out the chimney. It'll be a steep learning curve with different fire management but at least it should be one a once off relearning.
- Big T
- Moderator
- Title: Go Getter
That's awesome! Do you have an air intake or are you just using the door to regulate the fire ?
- Needs more Steel
Thanks! I was going to put an intake on the door but when I'd made it and felt the weight and snugness of the door I thought I'd just use the door to control air flow and save some extra unnecessary work. That said there is another way I can let air in but would be easier to explain with a video or more pictures.
- Needs more Steel
- dacolson
- Expert
I'm guessing the purpose of that vent on the bottom right in the second vid is to allow heat out of the FB on the side into that outer cooking area? Interesting.
I think I'd put a vent in the FB door. A baffle plate isn't a bad idea either since you can scorch meat sitting right above the throat. A vent in the door and a damper on your stack are a must however. That's a vertical smoker and vents/dampers are super effective at controlling heat. Just like a UDS or a komodo-style cooker. The door lets too much air in and with your stack wide open you no restriction to create back pressure.
Farmington, MN
Farmington, MN
- Needs more Steel
The 2nd vent is so that when I build the BBQ/Reverse Flow its essentially the opening of the FB (the two bricks can be used to block off either exit of the FB depending on what I want to use).dacolson wrote: ↑February 17th, 2021, 8:33 amI'm guessing the purpose of that vent on the bottom right in the second vid is to allow heat out of the FB on the side into that outer cooking area? Interesting.
I'd planned a chimney and damper for the vertical smoker just havent gotten around to getting it made yet
I was actually just watching the ChudsBBQ video on fire management last night and he was mentioning that if smoke is coming out of the FB door there could be too much back pressure? (I was getting this and found it hard to get a clean fire without it fairly open).
Its going to take a few times to get it dialed in but 100% the baffle is needed as the door was reading an average of 40degC and the probe 12 inches back was at 150degC.
Is it worth sanity checking the door probes by sticking them in boiling water, Pete? Sounds a massive difference, unless there's just a central vortex of hot air going straight up.
- Needs more Steel
Yep surprisingly I had tested them both in hot water before installing them so that only left me with the thought that the air is just rushing up and out the chimney (even though I closed it over with a brick as a test - however this caused the fire to burn dirty which would make sense)SheffSmoker wrote: ↑February 17th, 2021, 11:57 amIs it worth sanity checking the door probes by sticking them in boiling water, Pete? Sounds a massive difference, unless there's just a central vortex of hot air going straight up.![]()
- dacolson
- Expert
A few thoughts here. First, fire size. A vertical smoker can be very efficient with a small fire, vents and dampers. If you are struggling to control heat with vents/dampers and you are getting bad smoke, your fire is too big. Smothering it results in bad smoke. You had what looked like a pretty big pile of charcoal and wood going in there. Keep a shovel and bucket handy to pull coals out. I run a big green egg all the time which is basically a smaller version of what you are running. I use a small basket of charcoal and a lump or two of smoke wood with the vents closed almost completely and the top damper almost closed. It runs clean smoke for hours at 225.BigPete wrote: ↑February 17th, 2021, 11:17 amThe 2nd vent is so that when I build the BBQ/Reverse Flow its essentially the opening of the FB (the two bricks can be used to block off either exit of the FB depending on what I want to use).dacolson wrote: ↑February 17th, 2021, 8:33 amI'm guessing the purpose of that vent on the bottom right in the second vid is to allow heat out of the FB on the side into that outer cooking area? Interesting.
Also, You will struggle with a lot of wood in a vertical smoker b/c wood needs a lot of air. A smaller wood only fire will run out of coals quickly and you'll be adding often. Something to test if you are interested. Mostly charcoal with a couple fist sized chunks of wood for flavor will be a lot easier to control.
Chuds runs a couple different cookers - a standard offset and a direct fire cooker he calls the Chudbox. Both run differently than a vertical smoker like yours. The offset is controlled w/ the stack damper and fire size. If you damp it down too much, back pressure will cause smoke to come out at the doors. If you can't get your heat down without too much back pressure, you start to pull coals out. His Chudbox direct fire cooker runs hotter than a standard offset. 350+
Back pressure isn't a bad thing. It can be if you smother your fire but without some back pressure, you can't control your airflow and heat. It just heads up the the highest point and out the top in a vertical smoker. Even with a baffle plate.
My advice - put a vent in the door and a damper on the stack. Baffle plate is optional if you are looking to diffuse heat to the sides away from direct heating your meat. Use mostly charcoal or wood burned down to coals. Add wood chunks for flavor. I'd be interested if other folks feel differently. This is just my experience.
Farmington, MN
Farmington, MN
- Needs more Steel
Thanks Dave, yea all makes sense. The fire ended up way bigger than i'd expected as I was basing things on the door thermometers and I was also seasoning the inside so wanted it a bit hotter than a normal cook temp.dacolson wrote: ↑February 17th, 2021, 12:57 pmA few thoughts here. First, fire size. A vertical smoker can be very efficient with a small fire, vents and dampers. If you are struggling to control heat with vents/dampers and you are getting bad smoke, your fire is too big. Smothering it results in bad smoke. You had what looked like a pretty big pile of charcoal and wood going in there. Keep a shovel and bucket handy to pull coals out. I run a big green egg all the time which is basically a smaller version of what you are running. I use a small basket of charcoal and a lump or two of smoke wood with the vents closed almost completely and the top damper almost closed. It runs clean smoke for hours at 225.BigPete wrote: ↑February 17th, 2021, 11:17 amThe 2nd vent is so that when I build the BBQ/Reverse Flow its essentially the opening of the FB (the two bricks can be used to block off either exit of the FB depending on what I want to use).dacolson wrote: ↑February 17th, 2021, 8:33 amI'm guessing the purpose of that vent on the bottom right in the second vid is to allow heat out of the FB on the side into that outer cooking area? Interesting.
I'll build a small stack/damper and get that on, then see how the door is (its cross braced from the rear so a vent could end up being very small). On a side note, I may take the cap off the Brazilian chimney to see if it reduces the back pressure and saves me from having to put on the lip we discussed previously as thats my last resort
- dacolson
- Expert
Good idea. Change one thing at a time, right?
Farmington, MN
Farmington, MN
