Brick grill and smoker build!
Cole Leffert
Title: Country boy!
Re: Brick grill and smoker build!
Post by Cole Leffert » August 11th, 2020, 8:15 pm
dacolson wrote:
August 11th, 2020, 8:14 pm
Cole Leffert wrote:
August 11th, 2020, 8:11 pm
This is what the big bricks look like.
So cool.
Thanks!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 5th, 2020, 4:44 pm
I got a little farther today. Maybe I will be able to put up some more brick tomorrow.
Post by Big T » September 5th, 2020, 8:20 pm
Nice work!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 5th, 2020, 10:19 pm
Thanks, Big T!!
Post by Pete Mazz » September 6th, 2020, 2:29 am
Lookin' good!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 6th, 2020, 6:46 pm
Thanks Pete!
dacolson
Title: Lucky and grateful
Post by dacolson » September 6th, 2020, 9:28 pm
Dave C - QueNorth Smokers
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 7th, 2020, 6:39 am
Thanks, dacolson!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 13th, 2020, 9:03 pm
I didn't have a lot of time this weekend to work on it but got a little farther.
dacolson
Post by dacolson » September 13th, 2020, 9:27 pm
Coming along nicely, Cole.
Farmington, MN
Post by Big T » September 14th, 2020, 9:26 pm
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 15th, 2020, 2:07 pm
Thanks, dacolson and Big T!
Post by Rodcrafter » September 17th, 2020, 9:56 am
I always liked to see people build these block cookers. I never was willing to because of the "written in stone" idea. I always seem to think I need a way to change stuff if it doesn't work out just the way I want.
I was wondering about the smoker portion, since your going to need doors and racks and stuff have you thought about building a steel pit and putting it in like a slide in unit?
I think I would so if I want to modify it I could. I know you were talking about burning a fire in the FB, I do that in mine and have a CC just above it.
But I made the FB then added 2" of rockwool 2'000* insulation, then my CC on top of that with a 6" opening in the center that I can open or close however much I need to so not to overheat the CC.
https://imgur.com/oqfzdfs
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 19th, 2020, 3:27 pm
Thanks Rodcrafter!
Yes, I plan on making it a slide in unit. It will have an angle iron frame. The front will be steel plate with cut outs for the fb door, water pan door and cc door. I will slide it in then mortar it in around the front. If I have some real problems I could chip away the mortar around the front and slide it out and fix.
I do like your door between the fb and cc! I planned on putting in tunning plates to adjust flow and help with hot and cool spots. What do you think would be the best?
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 19th, 2020, 4:54 pm
Finally got all the cinder block work done!
dacolson
Post by dacolson » September 19th, 2020, 7:59 pm
Money. You gonna run that brick up all over?
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 19th, 2020, 8:06 pm
Thanks! Yes the whole thing will be bricked! I'm thinking about tile on the work surface around the grill, that would be the only thing not brick.
dacolson
Post by dacolson » September 19th, 2020, 8:12 pm
That would be sweet. Some of those tiled wood ovens look beautiful. I like what you got going Cole. It will be a focal point in the yard too.
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 19th, 2020, 8:17 pm
Thanks, dacolson!
Post by Rodcrafter » September 22nd, 2020, 8:25 am
Cole,
I would put an baffle plate between the FB and CC leaving the gap on the sides say 1-1/2 inches. Then as much as 4" above that, do it again with the opening in the center with you adjustable plate there.
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 23rd, 2020, 12:29 pm
Cole,
I'm not sure I understand how that will help (not saying it won't... I just dont understand)? The whole area between fire and cc is a bit of a mystery to me! What is the goal for my heat coming through the cc... do I want it coming up the center, around the edges or both? I do plan on having a water pan in there if that matters? Thanks!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 27th, 2020, 5:57 pm
I have gotten a little farther on the brick. I spend a lot of extra time rearranging bricks because the thicker bricks are also longer than a regular brick. Which means I can't lay them directly over the center of the previous mortar joint. I'm trying to keep it as random as possible.
dacolson
Post by dacolson » September 27th, 2020, 6:32 pm
Man, Cole, that looks awesome. Great look. Well spent time I think.
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 27th, 2020, 7:14 pm
Thanks!!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » September 29th, 2020, 12:29 pm
So from what I understand, my exhaust diameter/length doesn't matter since I am making a vertical smoker. So I am a big fan of doing things a little overkill and this is what I came up with for my exhaust pipe. I plan on using two 6" dia x 2' long pipes with dampers on top. Is this going to cause any problems?
