Brick grill and smoker build!
dacolson
Title: Lucky and grateful
Re: Brick grill and smoker build!
Post by dacolson » November 14th, 2020, 10:38 am
That’s got to feel good Cole. Great progress
Dave C - QueNorth Smokers
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 14th, 2020, 11:04 am
Yes it does! Thanks!
I have been worried about getting the brick work done before winter and it is to cold to do it. I actually had a small electric heater in the smoker with a piece of drywall over the opening to keep the heat in and keep the concrete above from freezing while it set.
Post by Dirtytires » November 15th, 2020, 10:37 am
I like it....
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 15th, 2020, 12:04 pm
I like it....
Thanks Dirtytires!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 26th, 2020, 3:06 pm
I finished the brick work on top of the smoker!! I also put some sealer on the bricks on the top of the smoker. I started a fire in the smoker to help try to keep the bricks a little warmer while the sealer dries. Since my doors on the smoker aren't done I used a piece of drywall to keep the heat in. I could of used a electric heater but I wanted to see some smoke coming out of those stacks!! 😁
I also started to lay out the tiles for around the grill.
dacolson
Post by dacolson » November 26th, 2020, 3:14 pm
:LG: that top looks awesome!
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 26th, 2020, 3:22 pm
Thanks Dave!
dacolson
Post by dacolson » November 26th, 2020, 4:40 pm
Thanks Dave!
Seriously - my pits will be around for years I hope. Yours will be around for decades!
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 26th, 2020, 7:07 pm
Thanks Dave!
I sure hope so! I tried to build it as strong as possible! I worry about all the constant freezing and thawing during the winter.
Post by Big T » November 26th, 2020, 10:34 pm
You'll be cooking before you know it!
tinspark
Title: Papa Oso
Post by tinspark » November 27th, 2020, 12:50 am
[/quote]
If you are worried about water getting down in cracks over time and freezing and causing cracks eventually, an awning with 4 pipes anchored in the ground and a little bit of 1/8" angle iron to screw the panels to may do the trick. corrugated metal in my area is relatively cheap. Home Depot has some vinyl stuff that I have used before, that is not too bad.. Plus awnings are nice in the blazing sun in the summer too. I have built several of them at work and for a few friends, I get remnants from metal building installers/ suppliers on the cheap..
Looking good!!
Regards,
Post by Dirtytires » November 27th, 2020, 10:20 am
I like it!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 27th, 2020, 10:29 am
Looking good!!
[/quote]
Thanks!
I have thought about doing something like that. I have been looking at ideas on the internet and nothing has struck my fancy yet! I'm leaning toward a wood frame with the corrugated metal roof... I think!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 27th, 2020, 10:30 am
I like it!
Thanks Dirtytires!
tinspark
Title: Papa Oso
Post by tinspark » November 27th, 2020, 3:27 pm
Looking good!!
Wood is good. I built a few patio covers at my house for both of my patios with wood. I poured concrete where the posts are and used those galvanized clips that pour into around it that are designed for 4x4 posts, That way the posts arent underground and rotting. I did some fence posts with a neighbor a few years back and set them in concrete and they are already rotting out. But the posts for may patio that I did at about the same time still look brand new.
Thanks!
[/quote]
Regards,
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 29th, 2020, 4:35 pm
I like that idea tinspark! Thanks!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » November 30th, 2020, 10:12 am
I have the tile laid. All I need to do is seal the grout. I am pretty happy with the way it came out! I'm starting to see day light!!!
BigPete
Post by BigPete » November 30th, 2020, 3:42 pm
This is looking really good, love that old brick look!
Post by Big T » November 30th, 2020, 7:52 pm
:LG: :LG:
dacolson
Post by dacolson » December 1st, 2020, 12:16 am
Yes!! So cool!
Farmington, MN
Cole Leffert
Title: Country boy!
Post by Cole Leffert » December 1st, 2020, 8:46 am
Thanks BigPete!
Cole Leffert
Title: Country boy!
:LG: :LG:
Thanks Big T!!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » December 1st, 2020, 8:47 am
Yes!! So cool!
Thanks Dave!!
Cole Leffert
Title: Country boy!
Post by Cole Leffert » December 7th, 2020, 8:24 pm
I started on the metal work for the smoker. I have the frame tacked together. I was getting ready to put in the cross piece that seperates the fb from the cc. The fb opening would be 22 1/4 x 22 1/4 and cc opening would 22 1/4 x 40 1/4. All of it is 28" deep. Do you see any problem with this? I know you guys said it really doesn't matter as far as function. I just wanted to make sure I didn't do something inconvenient, that would cause problems like to small of a fb opening and not be able to get wood in easily or something I am not thinking of.
Post by Dirtytires » December 8th, 2020, 10:36 am
You could probably cut down your firebox size a bit if you wanted. 2 inch for bottom clearance, 9 inch for a firebox and 4-6 inch headroom means you only need about 16 inches internal for your firebox. Just my opinion but a vertical is pretty efficient so a smaller firebox works well and helps to prevent building too big a fire.
Benefit is more room in the cook chamber.....
