Brick smoker with an offset chamber
jvjv
Post by jvjv » May 25th, 2020, 4:12 pm
Hello all,
New to the board. There's some great stuff here!
I'm currently designing a brick smoker - I see that most brick smokers are vertical designs. Is there any reason one can't build an offset smoker, provided you're using the proper dimensions i.e. the Feldon's BBQ pit calculator?
Cheers!
Re: Brick smoker with an offset chamber
Post by Big T » May 25th, 2020, 8:43 pm
Welcome aboard! You can build it with whatever materials that you want as long as it's built to the correct dimensions. Some materials are easier to work with and some last longer than others. Be sure to post some pictures of what you build so others can learn from your build. We usually learn a lot of what not to do along the journey of building a smoker.
Post by towtruck » May 25th, 2020, 8:48 pm
Anything is possible. Heat soaking into the bricks may rob you of temps........you could build it like the pizza ovens that insulate the cook chamber and brick over the insulation so your not heating up the entire stone work.
We want pics!!!!!!
dacolson
Title: Lucky and grateful
Post by dacolson » May 25th, 2020, 9:47 pm
Sub’d. Definitely want to see pics.
Dave C - QueNorth Smokers
Farmington, MN
Post by Dirtytires » May 26th, 2020, 12:17 pm
Welcome...look forward to your project.
