Disco Fever! Question about Disc selection
Yep... you need one of these too!
Elmacho
Post by Elmacho » February 7th, 2018, 10:24 pm
So, I found myself on the Agri Supply side of town and figured I would stop in and pick up a disc for a Disco I have been wanting to build for a few years now. Well to my surprise, I had options.
Is there a difference in 24" discs as far as metal or are they all pretty much the same? Some looked smooth, some looked like cast iron. I had no idea.
Re: Disco Fever! Question about Disc selection
Post by Dirtytires » February 8th, 2018, 11:53 am
I'd ask the counter help. When I on mine he only wanted to know what implement I was using. He got really quiet when i told him I was gonna cook on it.
The metal is of different hardness from what I understand. Dont know how to tell but I would pick softer to avoid welding cracks. My guess is the cheap/off brand will be softer. I didn't have a choice and got a hard one but have had minimial issues with it so I'm not really sure it matters much.
Most have a coating on them...That could explain the appearance difference.
I'm sure someone with some better experience will be along soon...
Post by ajfoxy » February 8th, 2018, 5:10 pm
I'd probably avoid the one centre bottom with the big ding in it were I you... :D
Post by The Czar » February 9th, 2018, 2:11 am
I think I seen heaven
Cole
Post by Cole » February 9th, 2018, 1:40 pm
Looks like a business opportunity!
Post by Rodcrafter » February 11th, 2018, 7:30 pm
I have found that the coating comes off easy if you burn it on a gas burner moving it around every now and then. It will turn white and brush right off.
Elmacho
Post by Elmacho » March 6th, 2018, 10:37 am
The Czar wrote:I think I seen heaven
It was truly an awe inspiring view.
Rodcrafter wrote:I have found that the coating comes off easy if you burn it on a gas burner moving it around every now and then. It will turn white and brush right off.
I was just wondering about that.
Elmacho
Post by Elmacho » March 6th, 2018, 10:38 am
What size flat bar is good for the ring around the outside? 1.5"
Post by Rodcrafter » March 6th, 2018, 2:59 pm
Yeah that
Elmacho
Post by Elmacho » March 6th, 2018, 3:01 pm
Rodcrafter wrote:Yeah that
Thank you!
Post by Dirtytires » March 7th, 2018, 1:28 pm
I went with 1 inch and am real happy with it. I don’t use mine for soups much so a bigger side was not needed.
Return to “Discada's! (Disco's?)”
