Grease fires
No Politics, No Religion... Smoking Allowed 8-)
Forum rules
No Politics, No Religion, Smoking is Allowed 8-)
Stewart
Grease fires
Post by Stewart » August 5th, 2018, 12:58 am
Boy did I ever have a bad grease fire today. Apparently the weld that joins my fire box to the baffleplate had cracked exposing live fire to hot pig grease. I had been cooking for about an hr or so when I noticed turbulent dark smoke coming from the stack. I opened up the cook chamber and boom! I had flames 4' out the stack the entire chamber was flashed over. Scary stuff I won't lie the pucker factor was real. The heat was so intense I had no way to really snuff it out. I was lucky enough to get the racks of meat out with little damage to them. Some of the #9 sagged where the heat was so intense around the base of the stack. Words can't describe the inferno I had lol. I was pretty helpless could only watch and pray it would burn itself out with min damage. I got the chamber snuffed out and was able to finish the cook without any further flare ups. I will take a few pics of whatever damages I can find in the morning. The seals around the cc door are toast I do know that much they burned up and fell off. Crazy stuff.
Re: Grease fires
Post by Big T » August 5th, 2018, 2:02 am
Wow!! I’ve heard about the grease fires and runaway pits, even saw some pictures of the damage but thankfully never experienced it. I’m glad you were able to salvage the cook with what seems to be minimal damage.
Re: Grease fires
Post by Chromeski » August 5th, 2018, 2:35 am
Wow at least you saved dinner. I'm definitely interested in pics and any what not to do tips
Re: Grease fires
Post by ajfoxy » August 5th, 2018, 3:47 am
Wow, hopefully not too much damage to your rig.
Re: Grease fires
Post by Pete Mazz » August 5th, 2018, 4:04 am
Glad you're okay
Re: Grease fires
Post by Rodcrafter » August 5th, 2018, 7:15 am
Wow!
cyberstrategist
BBQ Comp Team Name: Old Country BBQ
Re: Grease fires
Post by cyberstrategist » August 5th, 2018, 8:38 am
Glad everyone is safe, though! What smoker do you have that the weld broke?
Where faith + family + tradition always equals success. Serving up BBQ the old school way.
Currently using...
Five Barrel Cookers; One New Braunfels horizontal; One Trailer smoker (being built)
Re: Grease fires
Post by Dirtytires » August 5th, 2018, 11:39 am
Bummer on the flair-up. It sure ruins a normal smoke routine. Glad nobody got hurt....meat and metal can be replaced.
Stewart
Re: Grease fires
Post by Stewart » August 5th, 2018, 11:51 am
Yes I was lucky nobody was hurt just my pride...and eyebrows lol. All kidding aside I will be examining the inside of my smoker before each burn.
if you look close under the rail you can see the split and expansion
Stewart
Re: Grease fires
Post by Stewart » August 5th, 2018, 11:52 am
The weld cracked almost the full length and opened 1/8”allowing the perfect conditions for a flash.
AndrewPalmer71
Title: SmokinAddict
Re: Grease fires
Post by AndrewPalmer71 » August 5th, 2018, 1:13 pm
Wow! Did it split before the flair up, or from the intense heat of the flair up?
What welding process did you use and how thick is the plate, if you don't mind me asking.
Stewart
Re: Grease fires
Post by Stewart » August 5th, 2018, 1:29 pm
I suspect it cracked traveling from job to job. Maybe being still warm from a cook it was weakened enough to crack the weld. The baffle plate is 1/4" and the box is 1/4". I used a stick welder and had good penatration.
Stewart
Re: Grease fires
Post by Stewart » August 8th, 2018, 8:01 am
All fixed up and back in action. 12 racks 9 lbs poor mans burnt ends 100 poppers and 3 lbs sausage links.
Re: Grease fires
Post by mp4 » August 8th, 2018, 8:51 am
Awesomeness!
Re: Grease fires
Post by JKalchik » August 8th, 2018, 9:39 am
Stewart, that's a great pic of your pit.
Still, if you think your weld cracked during travel, I'd be thinking very seriously about adding some reinforcing underneath the cc & firebox to tie it all together a little better. Pretty obviously, something is flexing, and not in a good way.
Stewart
Re: Grease fires
Post by Stewart » August 8th, 2018, 11:09 am
This was the last burn on this trailer. She's going under the knife in the next few weeks. Her new home sits upon a cradle that supports the belly and the firebox. All supported by a 37' trailer (separate build thread).
Re: Grease fires
Post by Big T » August 8th, 2018, 4:15 pm
:kewl:
Return to “Off Topic Stuff”
