Welp.....I started my build.
Its been since last August since I worked on my smokers.
Anyways here it is, 32 inchs wide x 48 inchs tall and 24 inchs deep.
The inside is 409 stainless for the most part, only because I had it and it was cheep.
The top and bottom needed one inch added to each side to make the full 32 inchs wide. I wasnt about to loose those two inchs.
The stand took twice as long to build as the smoke box did. I had to have a way to move it though.
The last few pics show two bends, thats where the door will set into and seal against a gasket.
Since I have NO brake I had to cut a relief and then bend it. After I finished both bends then I welded it to get the strength back. Gettin er bent was a chore but now its done.
Insulation wont be here till the end of the week so probably wont be alot happen this week. Plus I need to figure where I want temp probe holes and such.
All said and done, its gonna have 3 inchs of insulation.
.........Sometimes I feel like a nut.
sorry Tom!, what I meant was Hey that is smoking,,,tom!, nice job!! a little play on words that read better down here upside down
