Best way to insulate
Instructional posts about How to use the Forums. Feel free to ask questions here also.
draw1983
Post by draw1983 » June 9th, 2017, 10:05 pm
Best way to insulate a smoker? First time build.Image
Sent from my LG-H910 using Tapatalk
Re: Best way to insulate
Post by mp4 » June 10th, 2017, 6:08 am
Rigid rock wool insulation panels like Roxul RHT80. It's good to 1,200 degrees and is readily available. You can get it at BBQ Smoker Supply
http://bbqsmokersupply.com/rock-wool-sm ... -oven.html or if you need different sizes at Zoro.com which is where I ordered mine through. I ordered one morning from them and it arrived the next day.
draw1983
Re: RE: Re: Best way to insulate
Post by draw1983 » June 10th, 2017, 8:50 am
mp4 wrote:Rigid rock wool insulation panels like Roxul RHT80. It's good to 1,200 degrees and is readily available. You can get it at BBQ Smoker Supply
Thanks for the info. Can't wait to get this thing wrapped up.
Post by Squiggle » June 11th, 2017, 4:17 am
Looks awesome, should be a beast! :kewl:
Post by Rodcrafter » June 12th, 2017, 9:16 am
That's gonna be a dandy
draw1983
Re: RE: Best way to insulate
Post by draw1983 » June 13th, 2017, 12:06 pm
draw1983 wrote:Best way to insulate a smoker? First time build.Image
Doors are on!!! Moving forward!!!Image
Post by Rodcrafter » June 13th, 2017, 1:53 pm
Do you have a sketch of this design? i just don't understand what you're doing with the bottom half. Did you run the numbers through the pit calculator?
I'm not trying to throw water on your fire so to speak, just want to help if I see a problem coming up since it is your first build.
draw1983
Post by draw1983 » June 13th, 2017, 2:00 pm
Rodcrafter wrote:Do you have a sketch of this design? i just don't understand what you're doing with the bottom half. Did you run the numbers through the pit calculator?
Trust me any help or advice is welcomed. The bottom is more of a skirt. I did run it in the pit calculator. And other than the fire box being a little bigger than called for everything is at least at the measurements the calculator gave..
draw1983
Re: RE: Re: RE: Re: Best way to insulate
Post by draw1983 » June 13th, 2017, 2:02 pm
The back side of the fire box is closed up now with the opening to the calculators specs. The throat is about 20% larger then the opening off the fire box.
draw1983
Re: RE: Re: RE: Re: RE: Re: Best way to insulate
Post by draw1983 » June 13th, 2017, 2:03 pm
Post by ajfoxy » June 13th, 2017, 5:27 pm
This is definitely an intresting build. Can't wait for it to flesh out a bit so I can see how it all works.
draw1983
Post by draw1983 » June 13th, 2017, 6:45 pm
ajfoxy wrote:This is definitely an intresting build. Can't wait for it to flesh out a bit so I can see how it all works.
Honestly I am ready to be done, however I think the end is only the beginning of more work!!
Post by Big T » June 13th, 2017, 7:07 pm
That thing is a Monster!!
draw1983
Post by draw1983 » June 13th, 2017, 7:28 pm
Big T wrote:That thing is a Monster!!
Yes the specs on it were kind of a dream, then when it was all put together; well the thought was if I ever have to actually fill this thing it will be a beautiful day in my world..
Post by Rodcrafter » June 14th, 2017, 7:29 am
There are a couple things that have me concerned 1. The throat opening (fB to CC) opening looks like it is about 4" below the top of the FB top. That will result in the top of your FB getting much hotter than it needs to because of the turbulence in the draft. 2. The BP gap (the opening opposite of the FB end of the baffle plate) you said it is going to be bigger "The throat is about 20% larger then the opening off the fire box" than the throat. This will result in slowing the draft. 3. The space you have below the throat under the CC, appears to be 1/2 + the size of the CC. I have never seen this done but my thought on it is, this area will require a much larger fire to heat it then heat the CC with what ever is left. I would consider a plate under the throat opening going all the way across to the other end. Then the "skirt would really be just a skirt.
I hope this is taken in a good way, not beating you up about your build.
draw1983
Post by draw1983 » June 15th, 2017, 3:37 pm
Rodcrafter wrote:There are a couple things that have me concerned 1. The throat opening (fB to CC) opening looks like it is about 4" below the top of the FB top. That will result in the top of your FB getting much hotter than it needs to because of the turbulence in the draft. 2. The BP gap (the opening opposite of the FB end of the baffle plate) you said it is going to be bigger "The throat is about 20% larger then the opening off the fire box" than the throat. This will result in slowing the draft. 3. The space you have below the throat under the CC, appears to be 1/2 + the size of the CC. I have never seen this done but my thought on it is, this area will require a much larger fire to heat it then heat the CC with what ever is left. I would consider a plate under the throat opening going all the way across to the other end. Then the "skirt would really be just a skirt.
I appriciate the in put. However I spoke with a friend that is helping me and he has the baffle plate in already. The opening on the fire box however is going to be opened up higher. (closer to the top of the fire box) I am going to start a fire in it see how it pulls and if I have to (before any meat) will cut the skirt off the back and place the plate on it like you talked about.
Thank you for the help
Post by Rodcrafter » June 15th, 2017, 4:04 pm
Ok cool
Post by temurf » June 18th, 2017, 9:53 pm
You definitely will be able to put a whole lot of Q on that thing. :kewl:
draw1983
Post by draw1983 » June 27th, 2017, 4:34 pm
temurf wrote:You definitely will be able to put a whole lot of Q on that thing. :kewl:
Well she is done. Cleaned her out and lit a fire today. Holds 225-270 for about 2 1/2 hrs between 2 split loads. Just a burn in today.. We shall see how she cooks soon.Image
Post by Big T » June 27th, 2017, 5:57 pm
:kewl: You may need to put some gaskets on those doors if you have any temp issues. If you see smoke leaking out it can draw cold air in once it establishes a good draft. Be sure to post some pictures when you cook on it or someone will say no pics never happened.
Post by temurf » June 27th, 2017, 6:03 pm
She sure is a monster.
Looking forward to the Q-View. :rulz:
Post by ajfoxy » June 27th, 2017, 7:55 pm
She really is a beast. And what Big T said about door gaskets.
draw1983
Post by draw1983 » June 27th, 2017, 8:13 pm
Big T wrote::kewl: You may need to put some gaskets on those doors if you have any temp issues. If you see smoke leaking out it can draw cold air in once it establishes a good draft. Be sure to post some pictures when you cook on it or someone will say no pics never happened.
I am ordering the gaskets tomorrow. I will definitely post some pics once cooking begins.. However I have to go back to work Thursday so it will be a bit before I get to do any Q..
draw1983
Post by draw1983 » June 28th, 2017, 8:43 am
Would you put the Gasket on the door or the CC itself.
Post by Rodcrafter » June 28th, 2017, 8:50 am
I always put it on the door
Return to “Forum How To's”
