120gal Reverse Flow Build, Fixing a "warped or sprung" Door
MaddogVPF
Post by MaddogVPF » May 6th, 2018, 8:40 am
First build with a friend. After mounting the door we noticed that we had between a 1/4-1/8" gap at the bottom. His idea was to create a wooden form for the inside of the tank in order to match the arc, then use four clamps to bend the door to fit the wooden form, then weld supports inside to keep the door's arc in place. Worked like a charm, although we did have to notch out the supports where they made contact with the front of the cooking grate.
Take a look at the pics for a visual.
Re: 120gal Reverse Flow Build, Fixing a "warped or sprung" Door
Post by Pete Mazz » May 6th, 2018, 11:00 am
Welcome!
Post by Dirtytires » May 6th, 2018, 11:21 am
Interesting idea...what is the thickness of the door?
Post by Big T » May 6th, 2018, 8:06 pm
Welcome aboard!!
Post by Frank_Cox » May 6th, 2018, 8:52 pm
:beer: welcome aboard!! thats a great approach! like DT said, what thickness door?
Post by Rodcrafter » May 14th, 2018, 2:31 pm
Welcome to the crew!
That was a great idea.
