newb smoker builder looking for advice
SteveJonesMO
Post by SteveJonesMO » March 14th, 2018, 6:49 pm
Howdy!
I've come into possession of a half dozen used sheet pan cabinets:
I'm planning to convert one of them into an electric smoker, and if that works well probably a couple more for friends and family.
My tentative idea is to insulate them (I want to be able to use them in very cold, windy weather), heat them electrically controlled by a smoker controller like this, using an external smoke generator like this, and a low volume fan of some sort to help keep the heat and smoke relatively evenly distributed through the chamber.
I will be trolling the "electric smoker" thread to flesh out the details and seek advice.
Thanks!
Re: newb smoker builder looking for advice
Post by Big T » March 14th, 2018, 7:20 pm
Welcome aboard!! It's probably do-able if you have a big enough element.
Post by ajfoxy » March 14th, 2018, 8:17 pm
Welcome to the crew. Yes, probably a bit of research into how much "electric" you will need to achieve what you are aiming for.
Post by Pete Mazz » March 15th, 2018, 4:22 am
Welcome
Post by The Czar » March 15th, 2018, 7:10 am
Welcome!!!
Post by Dirtytires » March 15th, 2018, 10:19 am
That is a huge volume....probably big enough to mover your “external” smoke generator to the inside and make 1 self contained unit.
Post by Rodcrafter » March 26th, 2018, 10:30 am
Welcome to the crew! It might be easier to split it into 2 chambers so you could even the temperature. Just thinking as tall as that is it may be a problem.
Post by Chromeski » July 30th, 2018, 12:07 pm
looks like a good find with potential just gotta work out the details
