Oil Tank Smoker plans
roastntoast
BBQ Comp Team Name: Roast' n Toast BBQ Team
Postby roastntoast » August 13th, 2011, 9:55 am
I just got an old furnace oil tank. Would like to make a pig roaster out of it . I've been looking all over the internet for Idears but can't seem to find much. Not sure if I want to go reverse flow or Charcoal tray in bottom with water pan. Anybody have any suggestions and or pictures ?
Thnaks
Jules
Jules
Re: Oil Tank Smoker plans
Postby Frank_Cox » August 13th, 2011, 10:03 am
Welcome roastntoast! Anyway of course I always have ideas :mrgreen:
I just have not drawn any plans for one of those yet. What do you have in mind as far as what you want or think would make this the perfect smoker?... Rotisserie?, plain ol hog smoker?, laying the drum down?, or standing it up?, trailer or no trailer?
I'm sure we can help ya hash it out :D
Update: 7/11/12....
Frank_Cox wrote:FINALLY! we have a set of plans for an Oval Oil Tank! This set of smoker plans is a reverse flow smoker and has 2 removable sections of the Baffle Plate to allow for use of Grilling Baskets for using this smoker as a Charcoal Grill also. This smoker also has a removable Rotisserie Spit and slide out racks.
Oval Oil Tank Smoker Plans fire box Right
Oval Oil Tank Smoker Plans fire box Left
roastntoast
Postby roastntoast » August 13th, 2011, 10:13 am
Well .. Hog cooker is what I was going for . I was thinking up right as well i have an old snowmobile trailer that I will use to mount it on. I will take some picture of the tank on the weekend. Just debating the reverse flow or charcoal tray in the bottom option.
Jules
Jules
Postby Frank_Cox » August 13th, 2011, 10:30 am
Well, anyone that knows me will tell ya I would go with a reverse flow for the temp control. If you did go reverse flow with that tank I would insulate it. I would bet it is only 1/8" thick or so.
I will predict smoker toms response.... "go with a center feed!" =))
He really likes that concept and I agree with him it is a real cool idea. A center feed is a reverse flow with the firebox feeding in from the center instead of one end. I have not built or operated this style as of yet but the principle is close to the same. I will not steel his thunder tho. I will let him have his say
:mrgreen:
roastntoast
Postby roastntoast » August 13th, 2011, 11:04 am
How would one insulate a tank like that. Wouldn't that be a lot of work ? Would you do the lid as well .
jules
Jules
Postby Frank_Cox » August 13th, 2011, 1:33 pm
All you hafta do is wrap the out side of the tank or firebox with fiberglass insulation or I prefer to use fire wrap kind of insulation and then put a skin of steel over that.
Postby Tom_Heath » August 13th, 2011, 2:06 pm
Ya, I'm liking the center feed jobbers. Probably not on a vertical tho. Let's see what Matt has to say, I was thinking that his was a different style feed.
Sent from my PC36100 using Tapatalk
Now Listen.....Thats what I say.
One of these days I want to learn to weld real good
I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party
MattS
Title: 'bout yerself
Postby MattS » August 13th, 2011, 9:41 pm
That tank has a wall thickness less than 1/8. Its closer to 1/16. But that isn't that big a deal especially with a reverse flow. I am assuming this is the oval shaped tank. My big smoker is a thin walled fuel tank just like the oil tank you have. As long as you keep it sealed up then it will work fine for hogs. Just need a good firebox and a thick RF plate and your set. If you go RF then you don't need to worry about rotisserie.
300gal RF w/ Propane Assist Firebox
24" CampChef SmokeVault
UDS
Postby Tom_Heath » August 13th, 2011, 10:48 pm
Jules, thats a fantastic avatar. I love it.
Now I need to find someone to help me out with making my avatar into a more cartoonish looking logo.
roastntoast
Postby roastntoast » August 14th, 2011, 7:03 pm
My bbq was done by.
http://www.barbecuelogos.com
great to deal with
Jules
Postby Frank_Cox » August 14th, 2011, 7:12 pm
Kool thanks for the tip :)
Postby Tom_Heath » August 14th, 2011, 10:13 pm
Yes, Thank You so much for the link.
roastntoast
Postby roastntoast » August 19th, 2011, 8:41 am
Here is a pic of my tank
looking to make somthing like this
Jules
Postby Tom_Heath » August 19th, 2011, 3:44 pm
I'm out of town workin a small storm or I would load a pic of a real nice looking rig with the same tank. If Frank doesn't find it, I will post it once I get back to the computer.
Postby Frank_Cox » July 11th, 2012, 3:38 pm
jon in mass
Postby jon in mass » September 3rd, 2012, 6:09 pm
anyone got any ideas on a horizontal center feed RF oil tank ?
Postby Frank_Cox » September 3rd, 2012, 7:08 pm
If you use the pitcalc on the main page everything works out the same. only thing left to do is put the firebox under the center of the tank. FB to CC opening is still the same only add a chunk of 1/4 plate 4" wider all the way around above the FB to CC opening and under your Baffle plate. The Baffle plate is still the same with the same gap just the gap is split between both sides.
jon in mass
Postby jon in mass » September 3rd, 2012, 10:10 pm
this is what i was thinking about (pardon the crappy drawing computers are like women rarly get them to do what you want)with a warming chamber on top of the FB
alleyrat58
BBQ Comp Team Name: TWSS! BBQ
Postby alleyrat58 » September 4th, 2012, 9:58 pm
Here are a few pics of my center-feed RF. Let me know if you have questions...
Postby Frank_Cox » September 5th, 2012, 5:03 am
alleyrat, I forgot yours was a centerfeed! :points:
jon in mass
Postby jon in mass » September 5th, 2012, 5:17 am
awsome rig, thanks, but i was thinking more of laying the tank on its side and even about taking 18 inches out of the middle of it. my questions are more about the RF plate. should i run it out to the front and leave the gap on the sides? and how much of a gap. (thanks for the detail ablut the extra plate above the FB to CC opening.)
also i was wondering about the flew. my thought was 2 stacks in the middle rear from about 6 inches above the RF plate
Postby Frank_Cox » September 9th, 2012, 8:47 am
jon,
I would put the gaps on each end of the smoker left and right of the door. since the tank will be on it's side the gaps will be shorter because of the long run front to back.
as far as the stack goes, I would put 1 stack in the center and on that big of a cook chamber you would want it at the top not near the BP. instead of taking 18" out of the middle of it you could put an upright plate in the center of the tank closing it off and make 2 cook chambers. make the firebox big enough for both and divide it in the middle also have doors on both sides of the CC and the FB have a 2 in 1 rig! :beer: :points: :welder:
jon in mass
Postby jon in mass » September 9th, 2012, 10:27 pm
thanks for the input.
haddnt thought of splitting it. would 2 FB be ness? or could i just use 2 openings with dampers in them with seperate controles.
also how do i tell how much of a gap on the BP ? is there a formular to tell? or woould an adjustable BP be better
Postby Gizmo » September 10th, 2012, 6:14 am
Adjustable - definitely adjustable ... they're not that hard to do and you'll have a lot better control.
jon in mass
Postby jon in mass » September 12th, 2012, 10:35 pm
hi frank. bein thinking about youre idea of making a two in one. also was looking at some other posts about squared off doors and did a little rethinking. hears what i came up with
was thinking of cuting one end off and welding it on the bottom as a smoke chamber. use two FB as two center feeds. in affect two 137.5 gallon units. with FB 24x24x24 (pit cal) it also comes out compact for my fairly small trailer 60x32
Who is online
Users browsing this forum: No registered users and 3 guests
