• Advertisement
Photobucket
hickory and pecan smoked brisket
Discussion about smoking Beef and Qview
Postby TuscaloosaQ » June 7th, 2012, 6:24 am
This is only my third brisket, I was told it was great and my on taste buds said it was wonderful too. My only question is can you cook brisket probe tender and it come out medium rare, I just do not see how it could be possible. I checked the internal temp, which I generally never, do at 190 it still was not tender with a probe. But then again are thermometers always accurate or correct.
TuscaloosaQ AKA"white knight of the blue light"
TuscaloosaQ
FA Builder
FA Builder
Title: Truly blessed
Re: hickory and pecan smoked brisket
Postby PvilleComp » June 7th, 2012, 6:59 am
That's perfect... it's not Medium rare... it's SMOKE RING!!!!!!
:LG: :beer: :grillin: :kewl:
PvilleComp
Postby dcman (The Czar) » June 7th, 2012, 7:21 am
:LG: :LG: .... :-w ..for my sample....and I don't think brisket is a cut of meat for medium rare and smoking.....I think you do that with tri tip..... :kewl: :kewl: :kewl: :kewl:
I wear big women's under all the time......so much room for me and Alleyrat.....
dcman (The Czar)
Postby alleyrat58 » June 7th, 2012, 11:11 am
We generally cook ours to about 200 - 205 depending on the smoker temp. If you cook at a lower temp your brisket will take longer, but will be tender at a lower temp - higher cook temp = less time, but higher meat temp. You get the picture.
:grillin:
alleyrat58
BBQ Comp Team Name: TWSS! BBQ
Postby Smokeone » June 7th, 2012, 5:36 pm
:needfood: :LG:
That look good enough to eat! :P Looking at the pics, i think that thing is cooked perferctly! :beer:
BBQ Comp Team Name: Smokerbuilder.com - Competition BBQ Team
Postby TuscaloosaQ » June 7th, 2012, 7:37 pm
Thanks guys, it tasted great, but I have always eaten beef medium rare, just dont see how you could get a brisket medium rare and it be tender but I am still learning
TuscaloosaQ
FA Builder
FA Builder
Postby PressureRanger » June 8th, 2012, 12:13 am
If you were grilling a steak, or having Prime Rib, or having a roast beef sandwich, sure medium rare or rare is awesome. But you are dealing with a brisket, which is one of the toughest pieces of meat on the cow. The reason it is used for smoking and low & slow BBQ is because the only way to get it tender is by cooking it low and slow, or making it into Corned Beef. If you were to pull it out of the smoker while still medium rare, it would be too tough. Consider Brisket the "exception to the rule" when it comes to being careful not to overcook your beef.
Pulling my pork....200 lbs at a time!!
PressureRanger
Postby TuscaloosaQ » June 8th, 2012, 7:13 am
PressureRanger that is the answer I wanted, thanks I kinda thought it was the exception to the rule, it weighrd 11 pounds and I was cooking most of the time 300 degrees or a little above. that being said the meat was way up on the rack, so was 300 really 300 at the point I was cooking. I like the way a guy said it on another site. It is "done when it is done"( Probe tender) he said all meat is different and I tend to agree with that. Still learning but the briskest was really really good.
TuscaloosaQ
FA Builder
FA Builder
Postby alleyrat58 » June 8th, 2012, 9:13 am
TuscaloosaQ wrote:PressureRanger that is the answer I wanted, thanks I kinda thought it was the exception to the rule, it weighrd 11 pounds and I was cooking most of the time 300 degrees or a little above. that being said the meat was way up on the rack, so was 300 really 300 at the point I was cooking. I like the way a guy said it on another site. It is "done when it is done"( Probe tender) he said all meat is different and I tend to agree with that. Still learning but the briskest was really really good.
TQ - I agree that brisket is an exception and you can't make a hard rule about when it is done, but one thing to consider which has worked well for me is to pull your brisket when it is a little south of tender. Let it cool to slow the cooking (maybe 2o or 30 mins at room temp), then wrap it up tight in foil (add some broth if you don't have any drippings...) and let it sit in a Cambro or an empty cooler and rest for 2 or 3 hours. It will tenderize a bit more and soak up all those good juices.
alleyrat58
Postby SoloQue » June 8th, 2012, 11:04 am
dcman wrote:I think you do that with tri tip.....
OK, it's time this simple bama boy learns another BBQ term. What is a tri-tip? My wife is a professional butcher and she cannot tell me what a tri-tip is. Is this a regional cut or just another name for a cut I already use? Heck I don't even know if it is pork or beef.
SoloQue
Next
  • Advertisement
Get our toolbar!
Return to Beef
Who is online
Users browsing this forum: No registered users and 1 guest
Photobucket
cron
