Snack sticks in my mini
Post by Weldun » May 27th, 2018, 7:42 am
Gonna give snack sticks a shot using my mini. Heat source will be a two burner hot plate , smoke will be supplied by pellet tray and will utilize temperature control fan for air movement. Currently set at 100*F and will bump up to 160* F in an hour. Eventually I'd like to experiment with a divider to reduce firebox volume to facilitate a smaller clean burning fire with less heat for making lower temperature goods.
Re: Snack sticks in my mini
Post by Weldun » May 27th, 2018, 1:27 pm
Turned out pretty decent for for first attempt, flavor and texture are spot on but casings are a bit tough.
Post by Big T » May 27th, 2018, 3:00 pm
I think it’s great that you’re thinking outside the box of what you can do with the GF. Most guys only use them as designed and miss out on all kinds of opportunities. Those snack sticks look great!
Post by ajfoxy » May 27th, 2018, 4:55 pm
:yth: Give each idea it's time in the sun.
hutcho
Post by hutcho » October 5th, 2018, 9:44 am
Did you put them in an ice water bath right after smoking?
Post by Weldun » October 5th, 2018, 10:17 pm
I didn't do the ice water, may do it in the future to see how it effects the finished product.
hutcho
Post by hutcho » October 5th, 2018, 10:19 pm
I do it every time. It shrinks the casing down and gives it a little snappier bite. Usually let them bathe for 10 minutes or so then hang in the fridge overnight. Then vac seal the next day.
Return to “FOOD!”
