Old Wood
Discussion about Woods for smoking
Jason B
Old Wood
Post by Jason B » May 28th, 2013, 12:19 pm
I have access to a ton of peach wood but I am not sure if it would be worth it. It is an old peach orchard an the trees have been dead/on the ground for 5 years or so. Reckon it's worth a flip?
Re: Old Wood
Post by The Czar » May 28th, 2013, 12:41 pm
Eek.....
Miketheforester
Re: Old Wood
Post by Miketheforester » May 28th, 2013, 6:41 pm
Other than the wood being very dry, it might be all right. The best pieces would probably be pieces that have been held slightly off the ground by limbs etc. It will probably have bugs under the bark, but that is no big deal, because the bark should fall off fairly easily when it is split and you would be fine. However, if it has lots of larger bug holes going into the wood or a lot of soft wood on the outside the wood may be no good because it will either put off an unpleasant smoke or burn fast and unreliable. But if its free, the worst you can do is give it a shot. I have access to a lot of free wood at work, some of it is normal and some of it has issues, but most stuff burns just fine even if it looks a little rough.
Clover Ridge Smokers
Title: Driven By Passion
Re: Old Wood
Post by Clover Ridge Smokers » May 28th, 2013, 7:23 pm
Re: Old Wood
Post by Gizmo » May 28th, 2013, 8:08 pm
All that potentially lost peach wood …. :(
And I was having such a good day …
Jason B
Re: Old Wood
Post by Jason B » May 28th, 2013, 8:28 pm
No worries Rick. There is still 20 acres of dead trees standing, I just haven't asked about those yet. :)
Re: Old Wood
Post by Gizmo » May 28th, 2013, 8:31 pm
Sheeesh! Don't scare me like that … :-o
Re: Old Wood
Post by Smokeone » May 29th, 2013, 4:05 pm
Peachy! I would follow MTF's advice. :beer:
Post by Frank_Cox » May 30th, 2013, 7:39 pm
Mike sure does know the wood! Begin a forester and all lol, maybe we can do a wood swap buddy!
Sent from my Nexus 10 using Tapatalk HD
Re: Old Wood
Post by Puff » September 29th, 2013, 9:16 pm
Since the topic is here, how old should wood be for the best smoking? I have acres of oak and some of it has 22-26" diameter logs at the trunk side. After I cut and split them, how long should they "dry" before the best use and what is the best size to split them down to?
Re: Old Wood
Post by Gizmo » September 30th, 2013, 6:30 am
I think most common blocking is 14 to 17 inches then split it all down to about 3" X 3".
With the exception of hickory and ash, 2 to 6 months after splitting and ricked outdoors should cure out most woods enough to get rid of the "green" odor/taste. Ash should sit a year (personal experience) and hickory you can cut in the morning and burn that night if you like and it doesn't seem to matter…
Try to use all of it up in 2 to 3 years if stored outdoors ….jm2cw :D
Rev.Mike
Re: Old Wood
Post by Rev.Mike » September 30th, 2013, 1:20 pm
someone was asking me the other day about using persimmon, any one ever use it? i have no idea, would think it would be bitter
Re: Old Wood
Post by Puff » September 30th, 2013, 4:40 pm
Thanks for that absolutely GREAT answer.
capt j-rod
Title: Captain of Seafood
BBQ Comp Team Name: BOHICA grilling team
Re: Old Wood
Post by capt j-rod » November 25th, 2013, 7:41 am
re:oak... we dry under a lean-to for a minimum of 1 year. 2 years is awesome. remember, you want btu's not smoke. smoke comes from apple, peach etc wet wood. Heat comes from dried seasoned oak. keep it out of the sun too. We noticed sun bleached has fewer btu's than covered. fwiw
Re: Old Wood
Post by Gizmo » November 25th, 2013, 10:09 pm
capt j-rod is that red or white oak? just curious
Return to “Wood”
